Question about Canon Office Equipment & Supplies
Problem with developing unit for canon ir1018
I have problem with developing cylinder because copy its very light.I put new dev.unit and problem its fixed.i used original toner and machie have only 10000 copys.
  • 3 Answers
Canon ir1018 showing error 354 code what is the cause
Posted on Jan 06, 2009
  • 92 Answers
Does the cylinder rotate easly , and the blade is cleaning the cylinder.
probably is the blade.chage it.
Posted on Dec 30, 2008
I have canon it 3300, all prints and copies out with some black dots on tope of the paper. How to solve this problem. Laser unit is not good and can headed the sound like a siron
Repeating dots are usually the result of foreign material on the drum charge roller or toner adhesion (like a little smashed melted blob) on the developer cylinder. You can clean the charge roller with water. To clean the dev cylinder, wipe the toner off the area, then use strong alcohol to clean any area with the little "blob" buildup. Rotate cylinder and repeat for any remaining. You can usually see the area before you wipe it by looking for a darker spot on the dev cylinder than the rest of the coverage area. Copies will look bad at first after cleaning either. Just run about 20 or so copies.
Jan 21, 2017 | Canon imageRUNNER 3300 All-In-One Laser...
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
How to change devolper
Remove the waste bottle then the drum unit from the front of the machine.**Cover the drum unit so it is not exposed to the light.
Remove the Developing unit and empty the developer from the dev unit into waste bag. Once all the developer is removed...take the new bottle of developer and pour it all into the dev unit. Replace the plastic cover back onto the top of the dev unit. Re-install the dev unit back into the machine, then replace the drum unit back into the machine then replace the waste toner bottle. Close the front door. Enter the copier adjustment mode on the keypad by pressing "user preset,Orig size(Ledger), and Multi-copy key #3 in sequence.
Then press Multi-copy key #8 , then press the Print key.
Now select th code "09" and Press Print.
The machine will run for approx 2 minutes to initialize the new developer. Press Clear/stop and User preset to escape from the service mode. You are done.
Jun 07, 2010 | Panasonic FP-7750 Black and White Copier
Copy light
did you try to print something from pc? Are the print is ok? If the print is ok and copy is not ok, clean the copy glass.
If your copy and print are not ok, clean the laser unit, check the transfer roller and contacts, check the developing cylinder and contacts,... and try with new drum UNIT!
Nov 26, 2009 | Canon iR 2020i Laser Printer
Canon IR1018 forces duplexing
Go to service mode MENU and #, clear all and ok,
after that machine goes to factory sett., reenter your sett. it should work
Jul 08, 2009 | Canon Duplex Automatic Document Feeder
Copies fine on bottom, but fade to nothing at top
Could be one of many things. Possible new transfer roller - make sure the transfer roller is not jammed.
Check the developer roller (at exit from toner hopper), to see if it is rotating properly. Check all connections to/from drum and transfer rollers.
This is most likely a dev unit problem. Not sure if dev/hopper and transfer are all in one unit - if so, replace the lot, or you'll be chasing one problem after the other.
Apr 10, 2009 | Canon Office Equipment & Supplies
Canon ir1018
your laser shutter is not opening you will have to have serviced
Mar 28, 2009 | Canon imageRUNNER 1023iF Black and White...
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
464 people viewed this question
old marine
old marine
