Question about MA Audio HK401SX Car Audio Amplifier
My brand new system isnt working right...
I just purchased a brand new MA Audio car audio system, when i turn up the gain, the speakers have an extemely loud, constant bass hit. I went out and bought a bigger ground wire for it, and i also purchased new RCA wires as well, as i was told that might be the problem. I'm not really sure what is going on, because i literally just got the system brand new yesterday. I cant think of anything to do, or find the exact problem. Any suggestions or for sure answers would be greatly appreciated!! Thank You.
  • 1 more comment
  • da big bitch Feb 10, 2008
    yeah, i have the same problem, i had my system wired before with an 8
    gauge wire which was way to small but it melted 2 of my fuses within a
    couple days. It was working and my solo X was kicking hard but now that
    i got everything re-wired with the zero gauge i havent heard the same
    sound quality that i heard before. i was showing my friends yesterday
    because i had just bought it and it was kicking but not to its full
    potential then after like 20 seconds of play it just turned off and the
    amp went into protection mode. the blue LED turned on and now the
    system refuses to play i dont know what the problem is but i wanna know
    if i could fix that. any suggestions would be helpful thank you.
  • juggalochant Jun 21, 2008
    i have a ma audio hk401sx and it was working then i switched it off and then it never turned back on? is there any reason or any way i can fix without sending it back? all wires are good
  • jrx7 Apr 26, 2009
    My problem is when I turn the gain a quarter of the way (not even), they continuously sound in a rumble (Definately not normal) Like it overloads the subs with too much power or something. like there is a switch or like a fuse trips and it the same sound out of 2 12 in subs no-name bandpass box from xscargo We've even hooked it up to a alpine type r swr-1022D in ported box and it does the same thing. We tried a different brand amp and it doesnt do it. Any ideas what the problem is and the 10 in was wired 4ohm
  • 48 Answers
All righty then, This is most often gaused by bad grounds. Make certain the ground of the amp is a solid clean connection. The best place is under one of the rear seatbelt bolts, next check the condition of the ground at the battery this has to be clean with a good connection to the chasis, third make sure the Head Unit also ahs a clean positive ground. If these do not yeild results then get hold of any littel portable radio, cassette player, mp3 player as long as it has a earphone jack. Get one of those cables that have a earphone plug on one end and RCA plugs on the other. Disconnect the RCA's from the HU and hook up the player. Power up the system and play back from your portable player, mess with the gain on the amp and see if you still have the same problem when playing back from the portable device. If the problem goes away then you probably have blown grounds on the RCA's on the head unit and only a repair shop can fix that or a new HU. If you still have the problem with the portable player then adjust your lowpass filters and cut off to a higher frequency until the problem goes away. The gain on these amps should never be used to make up for low output from the Head Unit. (another cause for this condition) Get a HU that has 4 to 6 volt sub outputs and crank the gain down on the amp. That gain control is to control distortion (over driving the amp) not to make it louder. If you want louder then go for the HU with the higher sub output voltage or go with a SUB with a lower ohm rating. Your amp is stable down to 1 ohm. Oh and double check if you have your subs wired correctly improper wiring at the subs can m ake this problem worse.
Posted on Jun 29, 2007
I have the amp hooked up and the power light comes on, but there is no power going to my subs.
Check your gains. Make sure they are not turned down all the way. Are you getting audio to the amp. Use an MP3 player with a headphone to RCA cable directly into the amp to make sure your getting sound. Check the speaker wire to the subs. Make sure they didn't get disconnected moving the box around.
Apr 19, 2011 | MA Audio HK797 Car Audio Amplifier
Can i turn up the amp manuelly in the audi A8
Yes. Find the gain control knob on the amp and turn it up to increase the volume. Be careful though, as turning this too high can cause clipping and distortion, which can damage speakers.
Mar 20, 2011 | MA Audio Hard Kore HK-898 Car Audio...
How much are the 15 inch ma audio worth
If you get half of what you paid for them, you probably doing good. I think folks are hesitant to buy used subs.....they have no idea what they have been thru.
Mar 20, 2010 | MA Audio MA15SY Car Speaker
I need a new voice coil and entire cone and surround replacment for my ma audio 2002 model ma100Xl 10" subwoofer. any Suggestions?
MA does not make a recone kit, and does not repair out-of-warranty equipment.
You have a door stopper i'm afraid.
Thanks for using FixYa!!
Sep 30, 2009 | MA Audio MA 100 XL Car Speaker
Laptop speakers & hp jack dont work, works with line in only
first try to reinstall audio drivers, remove audio device from device manager, install new drivers.
Apr 13, 2009 | Dell Latitude D820 Notebook
Yes i have a 1000 watt amp and when i turn it on it stays on fine until the bass hits and then it kicks off then it kicks back on and the problem reaccures
I believe you have your gain on the amp turned up to high. Try turning the gain down, or if you have a LOUD button on your headunit turn it off
Hope this helps
Apr 06, 2009 | MA Audio MA 1200XL Car Subwoofer
Gain control
I would check ebay i know i bought one from there before. Hope this helps
Jan 13, 2009 | MA Audio HK4000D Car Audio Amplifier
My ma audio hk 4000 amp is powered on no sound coming thru subs amps brand new
If there is no protection light on, be sure the input is on. Some head units need to be turned on manually (factory set to OFF).
Verify the subwoofers are wired properly.
A list of your components would help to solve your problem.
If it is new, it should still be under warranty - worst case scenario output transistor(s) blown, or power supply bad.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
MA Audio HK4000D please help me ?
Turn the system off and disconnect the speakers. Turn the system on. If the amp still goes into protection mode with no speakers connected, then most likely the output transistors are bad. If the protection light is off, hook up one sub at a time until you find the one that is causing the problem
May 21, 2008 | MA Audio HK4000D Car Audio Amplifier
Amp ???
Ever find a solution? i am having the exact same problem... didnt happen until i plugged in the bass remote they send with it...
Dec 28, 2006 | MA Audio HK4000D Car Audio Amplifier
MA Audio HK401SX Car Audio Amplifier Logo
144 people viewed this question
Top MA Audio Car Audio & Video Experts
Fahr Quad
Robert Rankin
Ronald Prier
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
