Question about Lowrance iWAY 250C GPS Receiver
Volvo s70 mass air flow problem...
I have a 98 volvo s70 it wasn't cranking up like normal so I had it diagnose and a code pop up P0102 it came out to be a mass air flow problem. So went to the closes parts store and order one for about 130 dollars. The probllem still continued so i went and exchange the sensor for a brand new one and it still didnt work. So it has to be another problem, I spoke to a mechanic I was told its the sensor. so now I'm getting ready to buy a sensor for 230 from volvo, just wanted to see if what could I do before hand.
    Genius:
  • 1,071 Answers
I am an ex volvo master aftermarket stuff just doesnt work on these cars get one from volvo
Posted on Jul 24, 2009
What is causing recurrent DTC P0102?
code p 0102 refers to mass air flow (MAF) sensor/volume air flow(VAF) sensor--low input===causes ---wiring short to ground--MAF/VAF sensor---ecm
check the wiring to the unit--plug connection
Mar 31, 2016 | 1996 Volvo 850
Volvo s80 T6 2000 error cood P0102
code p0102 refers to mass air flow (MAF) / volume air flow(VAF sensor-- low input===causes --wiring short to ground---MAF/VAF sensors---ECM
I would replace the MAFor VAF sensor after having each one tested to find the faulty unit.
Mar 04, 2015 | Volvo Cars & Trucks
Getting code reading p1171 for on a 1999 volvo s70, 2.4 liter engine
P1171 Long fuel trim upper limit problem
This is the MAF (mass air flow) Check and inspect the MAF duct and check for any torn duct it may require a replacement . And perform a MAF cleaning
Apr 22, 2014 | 1999 Volvo S70
Volvo 2001 s60 t5 can't keep the ralenti rpm at less than 1500rpm, the car constantly shut off.
code po172 is your bank 1 o2 sensor and code po121 is your throttle posit sensor that controls your RPMs .code po102 is your maf -mass air flow sensor. and code 01172 is a throw in code from the others cause problem. you need a o2 sensor and mass air flow sensor and throttle position senor
Dec 10, 2012 | Cars & Trucks
Volvo V70 code P0102
that means you have a mass air flow sensor problem located on air intake first try cleaning it be real gentle when cleaning ok thhey sell electrical spray cleaner at auto parts use that then clear the code auto zone can do that for free drive car if it comes back then replace the mass air flow sensor ok let me know
Nov 20, 2012 | 1998 Volvo V70
My 1998 volvo s70 go died when idle at stop i
I'm having the same problem. At first I thought it was bad fuel so I replaced the fuel filter to no avail. Then I cleaned the Mass Air Flow sensor which also didn't work. Is your check engine light on?
Jul 26, 2010 | 1998 Volvo S70
I got a code po102 for my 1998 s70 it says MAF A circut low input what does that mean should i worry?
you may have an intake leak after the mass air flow sensor, check intake hoses and vacuum lines,
Nov 15, 2009 | 1998 Volvo S70
Volvo S40 2.0T (2000 X Reg) P0102 P0171
Hi, Since you have both codes Fuel system lean and MAF low I would bet money on that you have an intake air leak after the throttle. Check all hoses connected to the intake manifold, gaskets, injectors are put in place etc.
Aug 22, 2009 | Volvo S40 Cars & Trucks
What is code PO102-PD
P0102 Mass or Volume Air Flow Circuit Low Input.
The actual Mass air Flow sensor is damaged. replace this sensor asap. it is located on the top of the throttle body.
Jun 21, 2009 | 1999 Pontiac Grand Prix
1998 Volvo S70 2.0L Air conditioner not working correctly
This may be one or two different problems. One could be the climate control unit itself. Surprisingly the problem with the air not changing the source will likely be remedied by a reprogramming by a Volvo dealer. Defrost is the delfault outlet if there is a problem with that system. As for the dial not having detents and the cold instead of hot air in the pass side, that could be programming, a disconnect with the heater door for the passenger side or it could be the control unit. 98 is a difficult year to diagnose and the dealer is likely the only one who can properly diagnose this car. The download at the dealer is an inexpensive fix. If there is a mechanical problem within the air system that could prove more costly. I'm not sure how much the control unit for the climate control system, but there are usually quite a few on ebay. Good luck and I would suggest visiting the dealer first for this one as it is the least expensive fix and could very well be the only problem.
Feb 20, 2009 | 1998 Volvo S70
Lowrance iWAY  250C GPS Receiver Logo
156 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
