Question about AEG Lavamat W1050 Front Load Washer
Replacement of drum bearing - AEG Lavamat W 1030
I treid to loosen the Allen key nut at the back of the drum but it is stuck. Must one turn it clockwise or anti-clockwise to loosen it?
It that the way toreplace the bearing or must one remove the whole drum?
Please provide me with the whole procedure to remove the old bearing and seal and to replace is?
If there are any specific hinds, please provide it as well.
Do I need special tools to do the job? Would I be able to do it myself?
Kind regards
Pieter Wagener
How does one loosen the ? Must one turn it anti-cloc
Drum is making some really nasty banging then screaching sounds when entering high spin - any ideas??
sounds like main drum bearings not common but if the bearings are worn you get the banging noise and as it slackens the drive belt you get screeching noise as the belt slips.
Nov 21, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Ajust the clutch
follow the clutch cable down till you come to a rubber boot slide the boot up loosen the 9/16 jam nut and 1/2 nut then go down and remove clutch cover there is a 11/16 nut and an allen bolt hold the allen and loosen the nut then turn the allen in until it lightly seats then back out 1/2 to one full turn hold and tighten the 11/16 nut replace cover go to the cable and adjust the 1/2 nut until there is 1/16-1/8 in freeplay at the clutch lever pull lever in at least three times to seat the throw out bearing then tighten the 9/16 jam nut pull boot down test ride good luck
May 18, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
Drum bearing neads renewing i nead diagram of assembly can anybody help
What is the exact model #?
check inside door of washing machine sometimes on the back, top area.
Some washers require special tools to replace the bearings.
http://www.pdxappliance.com
Feb 27, 2010 | AEG Lavamat 88840 Front Load Washer
I need to replace the bearing in an AEG Lavamat 1450. I've taken the back off the machine, but there isn't a traditional "spider", just a round wheel type thing attached with an Allen bolt. Can I have some...
Hi there.....unless your exerienced in this area...id advise you to seek expert help...the drive wheel securing bolt is of the torx type and requires a secial torx key to remove it....you will find that the outter drum has a series of torx headed screws around it which have to be removed and then the drum split...only after this has been completed and the inner drum removed will you have access to.the bearings.......
regards Sir Galahad
Aug 20, 2009 | Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG LAVAMAT W1450 SOMETHING LOOSE IN DRUM WHEN SPINNING
Sounds like the main drum bearings have gone, if you hold the the drum and can feel up and movement or it sounds noisy or rough when you turn it by hand then it is definately bearings gone.
Unless you know what you are doing ,I would not recommend a D.I.Y. repair.
Dec 14, 2008 | AEG Lavamat W1450 Front Load Washer
Random red stains appearing on clothes. Aeg Lavamat 50430
possible you have some red clothing in the gap between the tub and drum - there is nothing in the machine to cause red stains
to check, remove rear half of cabinet, remove heater (held by 1 10mm nut which just loosen and prize out heater) you can then see into the gap between tub and drum. shine in a torch and rotate drum by hand to see if you can spot anything. disconnect from mains first
Jul 23, 2008 | Washing Machines
AEG Lavamat 72640
Probably the motor is broken. Or the tachometer is loose from the motor.
Dec 26, 2007 | AEG Lavamat W1450 Front Load Washer
Washing machine-dryer AEg
it could be the drum bearings going
Nov 05, 2007 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat W1050 Front Load Washer Logo
601 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
