Question about D-Link DNS-323 (DNS323) Hard Drive Array
Can not access Dlink DNS313
I have DLink DNS313, 1drive hard disk dns usb/network drive. At first it is OK, now I cant see the DNS313 in my network as netwrok drive. But i use to connect as usb drive, it is Ok. I tried reseting, using new ruoter/switch. It doesn't work. Somebody please help.
  • bkanneh Feb 22, 2009
    can't log into D-Link DNS-323 Hard Drive
  • Anonymous Mar 14, 2009
    Yeah. Have the same here. Have you solved the problem?
    Novelist:
  • 181 Answers
When you said you tried resetting, did you mean you clicked on the reset button inside the hardware or did you mean you just rebooted?
* If you clicked on the rest buttion, then you need to configure again from scratch. Not sure if your data will still be available though.
* If you just rebooted, then the problem may lie in your LAN configuration. Do the following:
1. Try to ping the device using a PC connected to the same network.
2. If you are using DHCP, your device may just have been assigned a different IP. Try to ping all devices in your network or use a network scanner (e.g. SoftPerfect) to find out the IP address given to it.
3. Once you get the IP address, assign a static IP address to your device that is beyond the DHCP scope. This will ensure that your IP does not change and you will not have a conflict with DHCP assigned IP's.
Posted on Jan 04, 2010
  • thebaios Apr 12, 2011
    Hello Everybody,
    I had the same problem here. I phoned D-Link customer care and a guy said, do the following
    (I have the A2 hardware version, but he could only make the appropriate firmware available to me when I told him my 313's serial number):
    1.: Download the latest software for your device (mine is here: ftp://ftp.dlink.hu/dns/dns-313/driver_software/ClickNConnect/dns-313_DCC_1.03b04_V2.zip - this for A2 hardware)
    This package also contains the Click n connect software
    2.: Turn off any Firewalls (he said easy search utility sends Boradcast packages witch are denied in almost all firewalls, including WinXP's firewall). That's why had I never found DNS-313 with easy search before... if you afraid of turning the firewall off then disconnect from the internet and use your cable to connect the NAS to your computer directly . I did so.
    3.: Turn on the device with HDD inside and run click n connect. Follow the on screen instructions.
    First time I made a mistake by choosing the wrong answer on that page when 3 possibilities are there. I had to format the HDD but since then it is working.
    A strange thing that the guy said: DNS-313 _do not_ store firmware in an onboard chip, it is stored on the HDD. Furthermore, if your device hasn't got a hardware failure and your HDD is supported than you can reach your data with an USB cable. So if you have firmware problems simply backup all your data from the disk then reformat with click n connect and a firmware will be installed by the program.
    I hope I could help someone solving their problem!
    thebaios
Dlink 323 password reset
If you still need help resetting your D-Link 323 password, have you tried checking out the user manual? You can get it here:
Link DNS 323 manual
Aug 25, 2013 | D-Link DNS-323 (DNS323) Hard Drive Array
Hi i Just bought dlink 600 i am using compaq and has iphone and internet tv all of them cant connect by wifi my compaq can only connect with a cable. on my tv it says internet connection failed. and btw cm...
ok first prep. we need to configure your router. to do that we need your compaq laptop directly connected to the dlink via ethernet cable. after securing the connection, try to open a browser, whether internet explorer or mozilla firefox. go to the address bar and type in, 192.168.1.1 it would ask you now for a username. username is " admin " password is " password " if it wont let you in, try "admin" for password. if it still cant, try to live it blank and just click on login. it would take you now to the dlink router page. there you can configure your wireless connection and set your network name. make sure to click apply settings after configuring it. then try to check your wireless connectivity again. this should work.
Sep 02, 2011 | D-Link DIR-600 Router
Can i install my new dlink 615 without using the disk aS MY DRIVER IS BROKEN
Hi if your disk drive/cd drive is not working and you cant use the disk then all you need to do is go to google search and type in the following
type in either of these:
free firmware for dlink 615
or
free drivers for dlink 615
then hit search this will then list loads of sites that will let you download what you need for this device for free, now if you have to download them off another computer you need to download it onto a usb stick so as your computer can get the drivers put onto it.
if you can access the internet from your own computer then just download the drivers or firmware then it will install it for you, it might be worth typing in what os your using such as vista or windows 7 into the search as this will find the exact copy you need.
most sites will ask what operating system your using before it lets you download
have a go and you should find you will have no problems
let me know how you get on or if you need further assistance ok
Aug 03, 2010 | D-Link Computers & Internet
I need an install disk for my usb wireless adapter. I lost my disk.
OK... Just download the driver/software revision matching your USB adapter (have a look on it's sticker. If no revision is noted, then it's simply DWA-130!):
DWA-130:
ftp://ftp.dlink.com/Wireless/dwa130/Drivers/dwa130_drivers_130.zip
DWA-130_revB:
ftp://ftp.dlink.com/Wireless/dwa130_revB/Drivers/dwa130_revB_drivers_200.zip
DWA-130_revD:
ftp://ftp.dlink.com/Wireless/dwa130_revD/Drivers/dwa130_revD_drivers_100.zip
DWA-130_revE:
ftp://ftp.dlink.com/Wireless/dwa130_revE/Drivers/dwa130_revE_drivers_510.zip
I assumed you're using a Windows OS...
Mar 13, 2010 | D-Link DWA-130 Pre-802.11n Wireless...
Hello, I just bought DNS-323 and trying to start up it. I?m using one hard drive Seagate Barracuda 7200.10 ST3500630AS SATA 3G HDD 500G. I installed it in HDD1 slot and start the system. DNS-323 received...
I read that there are problems in some applications if you use only one disk in the 323. Try to move your disk to the other slot to see if this fixes your problem. Alternatively (if u have the money), you can try buying another hard disk of same brand/model and install it on the other slot.
You can then try setting up your device as a RAID1 or bigger (not recommended) JBOD configuration
Nov 22, 2009 | D-Link DNS-323 (DNS323) Hard Drive Array
I try to connect DLINK dns 323 to WD TV by USB cable but it not work how can i solve this
The USB port on the D-Link DNS 323 NAS is for a printer only. It won't work with your WD TV. Your best bet would be to plug the WD TV into a PC that is connected to your network along with the D-Link DNS 323 NAS and serve your media files that way.
Sep 04, 2009 | D-Link Dns 323 2-Bay Network Storage...
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
D-Link DWA-130 running Vista
OK!! I figured it out!! Ok you need to go to the Dlink web site, cursor over to the tech support tab, on the drop down select DOWNLOADS, enter your Dlink wireless adaptor version(you'll need the box for these steps), ok now in the new window click downloads, choose and download the 130 one not the beta version, have a flash usb ready and save all downloaded files to ur usb flash, next insert your usb flash on ur laptop, open my computer select ur removable drive and double click the dlink software, after you do this it should bypass that prompt screen and you'll be able to continue your setup for your Dlink wireless adaptor.........hope it works for you cause it worked for me.....
Aug 30, 2008 | Computers & Internet
D-Link DNS-323 (DNS323) Hard Drive Array Logo
7,167 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
