SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
SOURCE: Just replaced the heating element on my Raypak
Check your high limit. This is the reset switch behind the rubber button on the face of the heater. It probally tripped during the process and didn't get reset.
SOURCE: I've had my Raypak SpaPak (smaller model) for
If you do not keep close watch on your water chemistry, depending on your location , you could have a large calcium build-up or salt build up on your electric heating element. Also, these models are meant for spas, and depending on the weather in your location, the heater might have trouble keeping up.
SOURCE: CAN YOU PROVIDE ME WITH A WIRING DIAGRAM AS MY
Not much to a heater , you have a rheostat that goes from high to low heat . A coil or maybe two ,one for high heat and the other for low heat . Most of the time though they use just one with different voltage levels contrlled by the rheostat and a thermostat (keeps it from over amping the coils ). So it is one of the three ,I would guess the thermostat especilly if trhe coil is still in one piece. Rheostat you can test with an ohm meter to see if the value changes (Power Off!) and if it does it works. The coil if you have resistance its good (Power Off !) . Unless the resistance is real high then it could be in bad shape . The circut breaker is saving you from a house fire so thnk God for that. If it does it on low heat as well then I would suspect your coil if only on high Its definately your thermostat
