Question about Philips GOGEAR SA6045 MP3 Player
Playlist dont Show
I've GOtten all my music onto my playlist and sync'd then all inot the gogear 8gb mp3. So i disconnect and theres nto playlist. tho the music's still there. i just want my playlist, Can anyone Tell me what i did wrong?
  • Anonymous Jan 30, 2009
    I have the same problem.
  • 8,596 Answers
That player is set up for playlist transfer through Windows Media Player 10 only - you can either: 1) rollback your Windows Media Player to ver. 10; 2) attempt the firmware upgrade by running the Update tab in Philips Device Manager (may not work); 3) reinstall the installation CD - select Repair as your choice - it will add a plug-in that it may have skipped during initial installation. Good luck!
-Tha Mp3 Doctor
Posted on Jan 01, 2009
How to manually sync an ipod
You can make a playlist and then add the songs that you want to sync with ipod. Then in the music tab in itunes, just check the playlist that you want and then click sync.
Dec 02, 2013 | Apple iPod Touch 8GB 32GB 64GB 3rd...
On my Gogear Raga 2GB I can't make a playlist. (SA2RGA02). With WMP I can synchronise the music, but there's no playlist on the device. All the music is stored in different folders on the Raga and not in...
Sync all the songs you want onto the raga via 'songbird'.
Stay connected, then go to windows explorer, identify your device. Then in 'Music', make folders for your playlists. Manually transfer (drop and drag) your songs to the required folder/playlist.
When using the raga use the 'folder' option. Works as playlists.
grayza
Jul 10, 2010 | Philips GOGEAR SA6045 MP3 Player
Lookins for software
HDD14xx GoGear:
manual
software and drivers
The manual shows how to make lists and transfers with your player.
A short guide on how to use Windows Media Player 11:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your music maps and ad songs by drag and drop method
onto the right saying "Drag items here"
4. when ready adding songs in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 11, 2009 | Philips GOGEAR SA6045 MP3 Player
Playlist on go gear vibe
Using Windows Media Player 11 ?
Right click in the head of the WMP11 page: in Tools > Options... > Player : select "Keep the player on top ..."
Sep 11, 2009 | Philips Audio Players & Recorders
RE:WINDOWS MEDIA PLAYER 11 IN VISTA
Does your player show up as being connected in WMP11
Sync mode ? If not, a firmware installation for the player is needed.
If yes, did you perform doing next actions ?
3. Open your data maps and ad files by drag and drop method
4. when ready adding files in [Library] mode: "Save Playlist"
Sep 04, 2009 | SanDisk Sansa e250 MP3 Player
I have a Gogear aria black phillips 8bg mp3 player..playlist help
This is a good little player (although I don't kow why tey dont' include the actual manual for it)
It took me a bit BUT I found the manual online:
http://www.p4c.philips.com/files/s/sa1ara08k_97/sa1ara08k_97_dfu_eng.pdf
After you've created and saved your playlists...then clear the sync pane.
Then on the far left where all your playlist names are...highlight the ones you want and drag them into the sync menu. then click "Start sync".
After it's done I promise you all your playlists will be there complete with the music you added to the list
Aug 29, 2009 | Philips Audio Players & Recorders
Creating Playlists for GoGear Aria 8gb player
If you want to make a new playlist for your 8 gig GoGear Aria, all you have to do is highlight the songs you want to add, then right click the mouse and choose create playlist. Name the new playlist then cut and paste it into "Playlist" in the music choices and there you go. No WMP needed.
Aug 18, 2009 | Philips GOGEAR SA6045 MP3 Player
Cannot delete playlist folders on my gogear
My gogear SA52XX wont show the names of the songs
Jun 12, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips 4gb Go gear playlists
ok heres what ya do.
connect to laptop/computer.
go to "computer"
find the player -- open it
internal storage -- open it
playlists -- open it
right click any of the playlists and click properties.
click the references tab.
go back to the folder called music in the device.
click and drag the songs into the window called references.
when finished click ok.
should work!
Nov 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
147 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
