Question about Onkyo TX-SV525 Receiver
Reads PROTECT on the display of my Onkyo TX-SV525 ???
I have traced the amplifier circuit and found one shorted final transistor with a burned resistor associated with the transistor.The bad transistor was the left rear channel.I replaced both rear channel transistors with a new matched set and the burned resistor.I found no other problems in the circuit.I powered it up and the display reads PROTECT,with no output.I have a service manual,but I can find nothing about the protection circuit....
  • hggjyhg Nov 09, 2007
    how do you fix it
  • Anonymous Mar 16, 2014
    My Onkyo TX-SV525 power cord is missing. Where can I find replacement? Anyone got that part?
HOWDY,         NOW YOU COULD TRY THIS ONE: POWER THE RECEIVER UP , THEN PUSH&HOLD !THE VIDEO 1 BUTTON, THEN TURN THE PIECE IN THE OFF (STANDBY MODE ) ,IT WILL SAY "CLEAR SO IT SHOULD BE BACK TO IT,S ORIGINAL FACTORY SPECIFICATION,S.
SUCCES !                              AMSTERDAMCOWBOY-HOLLAND-NOW FLORIDA! 4-EVER
Posted on Oct 23, 2007
My AV-502A main amplifier fuse was blown,I checked the power transistors and found 2 shorted,C5198.I replaced it with new one, but the fuses still blown up, including the new transistors.
There are several reasons. If you find one shorted transistor in a push-pull stage you should always replace both. One might be faulty but not shorted, but when in operation it does the other one in. You might have also missed another shorted part such as a diode or voltage regulator. Hunt around looking at the circuit of the confirmed shorted parts and test or replace anything off that circuit.
Finally check your speakers and wiring to them. Shorted output transistors have generally two ways of going like that. Wires touching each other or bad speakers, or having it too loud!
Feb 02, 2016 | Audio Players & Recorders
Where can I get the scematic for the Veco 21 STC voltage control circuit board?
try mailing the manufacturer
hot transistors are usually shorted out, or driving a short!!
a multimeter across the 3 transistor legs (TO-3 transistors have 2 legs & the case which is the 3rd leg) will reveal if they're dead (remove the transistors first as the circuit may give a false reading) - if you get a zero ohms reading between any of the legs it's dead - don't forget to check the smaller driver transistors too,, as a dead main transistor will kill its smaller driver transistor
speakers are marked,, usually 4 ohms or 8, though sometimes 16 ohms - use a multimeter to ensure you have something very close to these values according to the label on the speaker box & measure from the wires at the point where they connect to the amp
power the unit without any speakers or speaker wires connected,, if the transistors still get hot, you're very likely looking at bad transistors
Feb 21, 2015 | Audio Players & Recorders
Behringer EP2500 drawing large current when powered up
If you are pulling the transistor that drives the final and the problem goes away, is the driver bad? Is the power supply a multi channel isolated unit? Could the channel for that side be bad?
May 18, 2013 | Behringer EUROPOWER EP2500 Amplifier
Peavey XRD 680 wont power up
Fuses blow because of an overload. Generally caused by a short circuit transistor(s) in the power amp section. Easy to spot with an ohm meter it will be like you have touched the test probes together!
Feb 24, 2013 | Peavey Audio Players & Recorders
Heat at some transistors and resistors in suv800x
most likely you have played your with either spk bad or bad wiring i have the same exact amp played it hard for more than two year and still have it sitting right now just bench test it last week still drive hard i think you make bad connection some for that to burn like that
Jun 18, 2009 | MA Audio Hard Kore HK-898 Car Audio...
Marantz SR19 no sound?
When replacing output transistors on amplifiers it is generally a good practice to replace the output capacitors as well as the biasing resistors. Just because one transistor is bad does not mean that that is the whole problem. Look for what caused the problem. Bad speakers,bad wires,defective traces on circuit board,poor soldering. Also when mounting the transistor make sure it is insulated and grease it with a dab of silicone heat sink compound. Whenever I service a board I examine all components for tolerance as well. A resistor marked at 1% tolerance,example 1k ohm + or - 1% should read no less than 990 ohms and no more than 1010 ohms. Anything else your asking for trouble. Another point is that some amplifiers use matching pairs. Pairs complement each other in an output stage and must be replaced in pairs. I repaired a Sansui Amplifier a while back and it looked as if a power output resistor was burned. Comparing the two channels I figured the matching value from the other side and replaced all of them and the system has worked flawlessly for years now. I am a retired electrical engineer and have worked in a few areas of electronics for over 35 years. Hope this information helps you.
May 06, 2009 | Teac A-1D 2-Channel Amplifier
I have a bose Lifestyle 5 music center. I previoously asked what may cause no out put to the sub and was told to replace R428 on the back side of the control module (not the sub) The person stated it was...
If the circuit board has a charred area, you have another problem besides the resistor. A short or overload likely caused the resistor to burn. Probably a blown output transistor(s) or chip(s), which generally short when they fail. This creates an overload in the circuit which burns up the load resistor - probably.
Dec 11, 2008 | Bose Acoustimass 15 System
I have a Marshall G100RCD guitar amp which keeps blowing fuses. Inspection of the circuit board appears to show to points that are burnt
You have a shorted output channel. You probably see burnt resistors and very heat stressed areas of the board. That is a sign of the outputs being shorted. Unless you have experience in repaired amplifiers you will not be able to repair this yourself. If you change the burnt resistors, they will most likely burn up again. The output transistors for one of the channels are also shorted. They must be replaced along with every other bad component. If you miss just one of the bad components you will most likely burn up all the good parts you just put in. Resistors must be checked to make sure they are within the rated tolerance, capacitors must be checked for being shorted or being dry, diodes must be checked for being open or shorted, output transistors and driver transistors must be checked for being open or shorted, and the list goes on. It is a very difficult job for anybody not experienced in repairing electronics.
Take it to a reapir center that will work on those type of amplifiers, not all repair centers will.
I am very sorry to give you such bad news, but it is the problem you are having.
If you need any additonal help feel free to ask, if you decide you are going to try and fix it yourself I can tell you what to look for and how to check them, but without the proper equipment you will not be able to do this.
If you found this information helpful a rating of "FixYa" would be appreciated. The "FixYa" ratings is not just for helping you fix your equipment yourself, it is also for helping you decide if you can even fix it yourself or not.
Thanks, and I hope you find a good repair center.
Dave
Jun 28, 2008 | Audio Players & Recorders
No power
My receiver has a similar problem. So far I have found a pair of output transistors fried shorted E to B to C (Q6051 and Q6061) and the associated ceramic current limiting resistor array (R6101) failed open. These bad components will definitely be sensed by the protection circuitry as an overload condition. I ordered some replacement transistors from Mouser (2STC4467 and 2STA1694) and the resistor (RSS2WK-0.22 ) from Encompass.
https://www.encompassparts.com/
I will let you know if this corrects the problem once the parts are installed. I also got a service manual from www.user-manuals.com which helps a lot.
May 27, 2008 | Onkyo TX-SR500 Receiver
Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Jan 29, 2007 | Marantz SR-7200 Receiver
1,043 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
