2005 Buick Rendezvous Logo
Ashley Posted on Oct 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Buick Rendezvous Shuts off when accelerating but starts right back up
We just the o2 sensor replaced as well as the computer. the car shuts off after being at a complete stop and you start accelerating again. everything shuts off no lights nothing, and then you put the car in park and put ignition to the off position and restart and it turns right back on
Marvin
Level 3:
Top Expert:
  • Buick Master 85,242 Answers
  • Posted on Oct 02, 2012
Marvin
Buick Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024077
Points
266281
Hello
The Engine and Automatic Transmission (not applicable to manual transmissions) in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for correct spec for your make and engine type.
5 Related Answers
Anonymous
  • 60 Answers
  • Posted on Dec 07, 2008
SOURCE: engine shuts off while driving
check one of your coolant sensor's
marionbagget
  • 718 Answers
  • Posted on Mar 09, 2009
SOURCE: how to replace a 2002 buick rendezvous o2 sensor
The O2 sersor will require a special socket to avoid damaging the wiring on the new unit. (the old one really doesn't matter so any socket that works can be used on it)
The first thing to do is spray a thread release agent like PB Blaster® around the threads. You should do it for several days between driving.
Call the auto parts stores to find one that has loaner tools. They will require a deposit until the socket is returned. It will look something like the picture. Yes you will need a socket wrench too.
WORKING UNDERNEATH THE VEHICLE, MAKE SURE ITS BLOCK UP SO IT CAN NOT FALL.
Some more information to consider from a forum
"You might want to take the O2 sensor you just replaced back and get two new ones. Some times new O2 sensors are defective, also when replaceing them I found it better to replace all of them at the same time for sometimes when replaceing only one the computer sometimes sends back false codes. Another thing is if you buy an after market O2 sensor the wires are just a little bit longer and can cause the computer to send back false codes. The best O2 sensors that I have found are the Boch Platinums designed for your vehicle."
Anonymous
  • 54 Answers
  • Posted on Mar 12, 2009
SOURCE: O2 sensors on 2002 buick rendezvous
hi im wes the o2 sensor is always in the exaust newer buicks have one before the converter (sometimes in the exaust manifold) one after the converter if it has duall exaust it could have four
left bank sensor one is before the converter on drivers side bank two sensor 2 would be passanger side after the converter does this help?
Anonymous
  • Posted on Apr 19, 2009
SOURCE: Buick Regal 2001 LS dashboard lights flash off and on
It turned out the ground wire to the battery was loose, Evidently, it loosened up when driving so mimiced the earlier symptoms because it connection was sporadic. I hooked up to a computer to verify after connection tightened and it came away with no errors or problems.
Anonymous
  • 365 Answers
  • Posted on Jun 22, 2009
SOURCE: I have a 2000 buick lesabre. The fix engine soon
It NEVER was the camshaft sensor! Unless, you've removed the engine lately, which I doubt.
RUN to Advance Auto Parts and buy a can of "SeaFoam" and add to your gas tank per instructions...drive at least 100 miles and the problem should go away...IF it doesn't you'll have to replace the O2 sensors in the exhaust system...Any good mechanic should be able to do this for much less $$ than the dealership DO NOT go to the dealer for repairs!
Good Luck
2answers
Where is the oxygen sensor on a 2006 Buick rendezvous 3.5 engine
There are four O2 sensors on your vehicle. Two for each bank of the engine. There will be one between the exhaust manifold and the catalytic converter and one near the end or just after the catalytic converter for each bank. If you are receiving a DTC indicating a sensor is bad, you need to see which sensor the code indicates. It will say something like bank 2 sensor 1.
2answers
My battery was disconnected now that the battery is back connected I'm having a hard time getting my 2002 Buick rendezvous to stay started and I do have an alarm system
It's my understanding that on these cars if you disconnect the battery for an amount of time the car computer shuts down and all the memory is lost till you reinstall the battery again. Then it takes a while for the memory to come back. The engine will stall and not run properly till the computer completely resets itself. They say just drive it and eventually in a few miles it will just keep getting better .
Hope it works for you.
1helpful
3answers
How many o2 sensors on a 2003 buick rendezvous?
If your vehicle has single exhaust, there are two oxygen sensors.
If your vehicle has dual exhaust, there are four oxygen sensors.
Buick rendezvous accelerating issues
Hard to diagnose without access to the vehicle, but I would try cleaning the Mass Airflow Sensor
Where is o2 sensor on 2002 buick rendezvous
as you face the car, on the right (driver side) in front of the engine is an air pump, a vertical canister device on a large metal bracket. the sensor is at the bottom of this assembly. you can trace the wires on the right side of the canister/pump.
hope help.
My buick will not start the security light is on and the radio works but the car will not start
GM Passlock security system does not reconize your key so it shuts off the fuel injectors.Computer thinks somebody is trying to steal it in other words.You will have to replace the key switch and or the switch housing but first if you have a spare key try it you other key maybe worn out and computer cannot read it. Hope this helps!!
2answers
Car shuts off after running for about 20 min after cooling off starts right back up have replaced computer but that did not help
this is an emissions problem , the cars o2 sensors go into closed loop when the car is up to operating temp and leans out the fuel to run efficently , it could be the evap canister or the 02 sensors , is it throwing any computer codes ?
2helpful
Top Buick Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
