Question about Acer n30 Pocket PC
Pd n30 new canot align screen with tapping it
[1] i could not get it to charge up no green light read you problem solvig section i found the hard reset switch was not in the on position it now has a geeh light
[2]i now cannot go past the sceen alighnment by taping screen what do i do next
  • Muffett 2 Jan 16, 2009
    i have solved all the problems
    no [1] hard swich was not in the proper position .
    no[2] the problem with the alighnment of screen was an operators error i did not tap on the crosses
    all now working thanks for your support
    muffy 2
I had a similar problem. I sorted it by doing 3 hard resets and a soft reset. You could try that.
Posted on Jan 15, 2009
I have acer n30 pc pocket. when i connect the usb cable for chasrging it dosen't get start and i can see the message on the scree "align screen" so what is a exctly solution pls tell me...
This happens when you get new one or after reset. It wants from you, to touch 5 points on the screen to calibrate touch screen.
Start acer without connecting usb cable and calibrate it first.
Jun 10, 2011 | Acer n30 Pocket PC
My asus p552w has align screen problem... when i enter this option it doesnt come out of it... just that target moves when i click/tap on it... it was getting clicked on right portion of the screen only so...
Hi Prash,
The solution is simple. Please tap the screen exactly in the center of the '+' sign that appears on the screen. The + sign or the target keeps moving till the screen is not alligned. I faced the same problem and searched and found your query on many forums but no luck. So I actually resorted to aiming the target with one eye closed...and the damn thing worked in one shot.....Now my default settings have been installed. Lets see what is in store on the other side of the default installation.
New Asus P552W user!
Nov 17, 2009 | ASUS Computers & Internet
Screen is frozen at the green Align Screen. Tried
Here is your drivers link kindly go and get it
Sep 07, 2009 | HTC Touch P3450 Smartphone
Acer N30 PDA charging problem
My PDA n30 is not a year old yet - when I put it to sync and charge everything looks fine but when I unplug it does not stay charged - it blacks out straightaway.
Please help
Jun 09, 2009 | Acer n30 Pocket PC
Acer n30 Screen Tap Freeze
Sounds as if the touch screen membrane is defective, which is a darned nuisance, but not impossible to fix .... if you are confident of dismantling the n30, you can buy a new touch screen membrane from Ebay for about 4 pounds/6 dollars.
It is a very skilful job to remove the old touch membrane from the actual display screen below it, not really for a novice, and all internal components are very delicate, so i suggest you find a tame technician before you buy the new membrane. The touch membrane connects to the motherboard via a tiny flexible 4 or 5 pin membrane ribbon cable, it's a miracle of miniature engineering inside the n30, so do ve very careful if you decide to do it yourself, best of luck!
Nov 22, 2008 | Acer n30 Pocket PC
Get to Start menu
I have same problem but found a work-around. I have found that 2 SD cards kept in the pockets in the flip over cover of my leather case has caused scuffing to the touch screen and the screen will now not align properly. In the alignmet utility I have to tap the centre of the alignment cross in the middle and 2 top positions and tap about 3mm above the cross in the bottom 2 positions (portrait format). This means of course that the bottom of the screen is out of alignment and I have to tap high at the bottom of the screen but I have got used to it. Not great, I know, but its better than nothing.
Oct 13, 2008 | HP iPAQ HX4700 Pocket PC
Would u plz tel me wat to do
I looking for Charge Cable for Pc Pocket Acer n30-B
Dec 30, 2007 | Acer n30 Pocket PC
Acer n30 will not turn on
Trya hard reset, mine was off for 6+ months and wouldnt charge. After a couple of hard resets - bingo, fully charged battery.
Oct 31, 2007 | Acer n30 Pocket PC
My n30 can't charge, but turns on under charging
hi, I had the same problem so i checked some other forums. I then found the answer. While your acer is plugged in, hard reset it, this switch is on the bottom of the machine. Switch the hard reset thing to the left for five secs, then back to the right. The green light should start flashing! You just fixed you acer!
Jul 28, 2007 | Acer n30 Pocket PC
Acer n30 Pocket PC Logo
158 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
