Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Krups XP2070 - expresso part - timing
Although I program the timing as per the documentation, it's impossible to obtain that the expresso turns more than 5 secondes and I really need more !
Do you have a solution to increase this time ? thanks !
  • Muehle May 12, 2009
    The espresso function suddenly started to deliver only about 50ml liquid and then the screen flasher as though it's an error. The instructions on how to change the quantity of liquid delivered make no difference/don't work. Checked everything. The machine is in excellent condition, works perfectly otherwise and is regularly descaled. Any suggestions?
    New Friend:
  • 39 Answers
It sounds like your flow meter is not working properly. Most likely it goes for about 5 seconds, stops and starts blinking with all the icons on. You can replace the flow meter and get it working again.
Posted on Dec 29, 2009
I have a krups xp2070. The espresso side powers
Sadly FIXYA has no clue as to your abilities to repair , and most times we find that coffee makers are not consumer repairable anyway
Jan 21, 2018 | Coffee Makers & Espresso Machines
Where can I buy the water flow meter When I start the machine, it warms up properly and after the lcd shows it ready, I select the numbre of cups I want. Unfortunately, the machine only pumps a small...
Same problem I have, flow meter! you could buy it @ although I am not sure which cluster you would connect the flow meter to the power board. My husband and I have opened the machine and we forgot to reconnect the flow meter to the power board. If you could take a look for us either J3 or J6 I will be more than happy to know. thks
Mar 24, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
I have a krups xp2070 that i just put a new motor in. When making espresso, the water pump does not turn off. Is it related to the little relay switch that connects to one side of the pump?
The unit is programmed to operate the pump for a very specific period of time depending on the function. Power to the pump is provided by the main power module but controlled by the control module. Either the module is not sending the right signal or the relay on the power module is stuck on. You could try programming the espresso time to reset the pumping time. Will the pump stop if you press the espresso 1/2 cup button again?
Dec 12, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
My Krups combo espresso/ coffee maker xp2070 will not turn on at all. No blue light when hit either start/stop button.
Do you have power to the control module? Can you set the time or is the display completely dead? Mine was completely dead and I replaced the power module and the display/control module.
Sep 13, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
I have a krups xp2070 coffee/expresso maker just stopped working
Most likely your power module failed. Mine went bad after 18 months of operation. You can order a replacement power module and control module from a Krups service center or from The replacement is not easy since you have to disconnect all the electrical connections. The module is about $60. I don't know how much the service center will charge to replace it.
Jun 13, 2009 | Gaggia Syncrony Logic 74884 Espresso...
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Cannot power up a krups xp2070 coffee/espresso maker
I did not find a repair manual. Most likely you need to replace the power module or the control module. They sell the power module and control module for < $60. It is difficult to replace but not impossible if you are good.
May 10, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
397 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
