Question about Hobart D300-6036 Mixer
The ball turns in opposite direction.
This is a commercial, three phase italian dough mixer. We have checked the wires, but nothing helped. When we switch it on, the ball turns the opposite way that the arrow on the ball shows, and the dough hook falls off. Does anyone knows what could be wrong with it?
Thank you.
    Novelist:
  • 125 Answers
You have a 3 phase unit, it can run opposite direction if the main feed wires are not correct for the motor wiring. If you simply swap any two of the main electrical feed wires it will run in the opposite direction. This should correct your problem now. Enjoy.
Posted on Dec 30, 2008
My Kitchenaid Mixer stopped working. Saw a mention of replacing the thermistor? Or is it the motor or control panel?
Make sure that the carbon brushes are not worn out or if you have already had them out make sure that they have been put back in properly. There is one corner ground off each brush that needs to line up with a blocking corner in the brush holder. Then get your multi meter out and check the unplugged main cable for continuity to the speed control panel. Then check each half of the field assembly for continuity from the speed control plate to a brush holder. Check you have no broken wires to the speed control plate. Check that the switch on the speed control plate is functioning. If all that tests OK I'd replace the phase board, it's worth not much and worth a shot.
Jul 28, 2017 | KitchenAid Food Mixers
Hobart h 600 mixer dough hook keeps coming off during operation. What would cause this
Take a look where the agitator pin engages with the dough hook.
Either the agitator pin (sticks out from the agitator shaft) is worn out or the groove in the dough hook where the pin should sit has elongated and worn. Either pin replacement is in order or new hook is required...possibly both.
Jul 04, 2014 | Food Mixers
The Kitchenaid Artisan stand mixer is spinning too fast after a voltage fluctuation.
Replace the phase board, that's the small pcb under the back cover with 6 wires coming out of it.
Feb 13, 2014 | KitchenAid Stand mixer 5qt art red
Three of my hobart mixers are spining wrong what is the problem
These must be 3 phase mixers (electrically there are two choices, single and three phase) Three phase cables typically have 4 wires, black, white, red and green (green is ground of course) To reverse the rotation of your mixers you would have to swap two of the three colors, and it doesn't matter which two of the three you choose, DO NOT SWAP THE GREEN, LEAVE IT ALONE. for example, just change red and black wires where it they connect to the plug. Of course turn off the power, unplug the the mixer, and usually you can take the plug apart and reverse the wires. If your units are hardwired you should call an electrician in to do it, it will only take a couple of minutes. cf652f29-33fe-4eee-8e37-1addfd1bcb1a.jpg aec28350-7e8b-4d45-a617-78e7a23dbf21.jpg
Sep 04, 2013 | Varimixer W20J Stand Mixer
Kitchenaid Hobart K45SS when set at 1-2 accelerates to high speed when making dough. How can I fix this?
Usually when the mixer runs only on high speed it is caused by the control plate adjusted incorrectly or the control plate spring unhooked. Remove the trim & end cover on the mixer and check the control plate spring, if unhooked, attach to bottom of the control plate and squeeze the spring end, also check the speed control plate screws,there are 3 screws on this plate, one at the bottom two at the top, see if adjusting the top screws slows your mixer down.
Next check the wiring of the mixer, Insure everything is wired correctly, to get wiring diagram go to the last page of the service manual. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
If neither of those fixes the problem it is probably a bad phase control board, or a shorted phase control board. With the line cord disconnected, pull the t-bar contacts to open and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run, if it operates at full speed the phase control is defective and needs to be replaced.
Use the service manual to aid you in taking apart the mixer, trouble shooting the problem and putting the mixer back together, based on the mixer only running at high speed some of the time I would assume it is the speed control phase board.
If you have any questions let me know.
Thank you,
Colleen
Customer Service
MendingShed.com
Apr 24, 2013 | KitchenAid Food Mixers
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
K5ss no power tested cord-ok inside all wires (red blue etc.) test ok. white on lower right hand side shows nothing on meter.
It sounds like you need a new speed control phase board:
http://kitchenaidmixerspares.co.uk/SearchResults/tabid/37/Default.aspx?Search=phase
Jan 18, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I have a Hobart 80 qt. stand pizza dough mixer that has lost forward speed, and only works in reverse. Is this electrical controls or a gear problem?
if the mixer is a 3-phase unit, that mixer has no reverse speeds, all gears should turncounter-clockwise when mixer is on ,if a 3-phase unit try switching any 2 of the incomingline to to change direction
Oct 08, 2009 | Hobart D300 Stand Mixer
Dough riding up dough hoook
Chances are you have a 3 PH motor and the motor is running backwards. Take the plug and unscrew the 3 or 4 screws. look at the wiring and change any two of the wires. DO NOT CHANGE THE GROUND WIRE! That one is usually green, but can be noticed by the curved tip as well.
If you do not have a three phase mixer, chances are your dough is too thick or too wet.
Jul 30, 2009 | Hobart D300 Stand Mixer
Hobart D300-6036 Mixer Logo
91 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
