Question about HP LaserJet 5550 Printer
Dark Green Instead of Black on Cardstock setting
Hp made me go though a month of paper samples untill they finally said "I have run tests on a 5550dn printer and have the same result as the samples you sent to our print lab." They will not fix or replace.. Come on guys its only 2 months old... and my case number is over a month old.... don't tell me I'm out $3000.00... They said.... "This issue follows the printer model and replacing it will not resolve your issue. I apologize for the amount of time it has taken to come to this conclusion." Any suggestion how to get the "Accurate Color" that they sold me on, come out of the printer? Are there any fixes out there... Just looking for The 4 color version of BLACK to print on cardstock...
  • covercash Feb 06, 2009
    Did you ever find your answer... We are having the same problem?
  • 40 Answers
If it's only 2 months old (3 now) and your case number is still unresolved, call HP directly and wade through their auto-answer system to the company directory. You're looking for a gentleman named Barry Tutt, he's the Great Lakes Regional Manager and VERY dedicated to customer satisfaction. Sound irate. DO *NOT* TELL HIM WHO GAVE YOU HIS NAME! Just say you got it from a former technician. If he can't get to the bottom of it, no one can. Let me know how it turns out!
Posted on May 29, 2007
Ink does not stick to page on m2727 when printing cardstock. We have tried using different paper settings.
Are you using original HP toners or 3rd party (refills)? We have had issues with some 3rd party toners not bonding properly on heavier media. How heavy a cardstock are you trying to print on? If it is heavier than the highest rated paper for this printer then it may not bond at all, regardless of toner used. The heaviest paper that HP rates for this printer is 43 lb/bond. A lot of cardstock starts at around 65 lb/bond.
Jun 15, 2011 | HP Laserjet M2727nf Multifunction Printer
My HP C4480 printer is printing red instead of black
My documents were printing red instead of black so I installed a new black cartridge. No it did not solve the problem. Yes I did run the utility to clean the heads. I finally went into the Printer Properties, advanced settings and set Print in Grayscale to Black Ink Only and it worked. You may need to turn off other settings related to photo printing.
Sep 15, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
Jan 28, 2010 | Provo Craft Cricut Disney Font Cartridge
Paper jams in manual feed tray when using 5371 cardstock however, printer works fine when 8315 cardstock is used (except for a black smudge spot in center of print-out). Printer is a HP 3505.
The Reason in roller of the seizure of the paper, or in brake platform under roller, wipe the roller by facility for rubber or for cleaning the surfaces, or change the roller and brake platform. The Roller seizure papers has a resource of the wear-out and brake platform under roller too. Good luck
Apr 13, 2009 | HP Office Equipment & Supplies
Jam in top cover area
Replace your paper pickups and set your paper tray setting correct, both in the tray and the settings menu. That should help you out. The part# for paper-pickups is RF5-3739.
Mar 17, 2009 | HP LaserJet 4600dn Color Printer
Printer won't print out test paper.
you may try this
1) do clean nozzle cycle (do more times) until print normal, refill enough ink., not fixed go next
2) clean the color ink cartridge nozzles, put the cartridge down the soft paper damped with solvent or water, do it again untill to see three different color inkgo out on the paper.
Feb 08, 2009 | HP PSC 1600 InkJet Printer
Epson 1400 wet black blocks of ink output
When this happen it means that your Fuser assembly and printer interior has toner contamination and build up. You can replace your fuser or run some more test print. Usually, the printer corrects itself.
Jul 26, 2008 | Epson Stylus 1400 InkJet Photo Printer
Printing Business Cards on Cardstock
It could be.
Part of the problem with that machine is that it has to bend the paper to get to the inkjets. If its too think it will stop running.
We use this Avery stock for printing business cards that might be a little thinner cardstock. I would look for some recommended for ink jet printers.
Jun 13, 2008 | HP Officejet 5610 All-In-One InkJet...
HP 6110 All in one
Various models do different things so you will have to checkout some stuff. 1. black is green- what it mean is if you take some black ink and wet it to dilute it will sh0w dark green then lighter etc., because black is all colours mixed. In most printers when a 'black' document is printed actually all colours are printing - take a look under a magnifying glass. Some printers however allow for 'black' only printing. But you have to set it up. So check your manual and software or what comes up on the screen. Then come come back
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP LaserJet 5550 Printer Logo
138 people viewed this question
Clive
Clive
