Question about Video Game Consoles & Games
Hello i got my little boy an ps3 for xmas.I set it up and started to play lego batman and it worked fine then after the first level the screen went black and now it wont play any disc the menu is staying on i have tryed reseting it but have had no luck please help
  • 1 more comment
  • jonnygowland Dec 29, 2008
    my ps3 will not register any games or dvds. When I put the games in ,which are new games the menu screen stays on and there isnt a option to play them, so the menu screen remains on and am unable to do anything with it. Have tryed turning off also restoring?
    how will i get a softwear update for my ps3
    thanks very much i have rang the number they are coming to pick it up on the 5th so should have the new one soon. thanks again my little boy is really pleased.
    Genius:
  • 1,239 Answers
Hi
Return under warranty.
the blue ray laser will have been slightly overheated and as a result will need to be replaced.
Posted on Dec 29, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 29, 2008
    This is a solution I found in one of the blogs, it worked fine for me:
    1. Connect the ps3 to the Wiimote and press Home to see the menu options.
    2. Press A + 2 + Z together which should result in a short ?ping-like? sound.
    3. You have now activated the interlaced mode.
    4. Leave the menu and you should see the normal game screen.
    5. To switch back to regular mode use the same method above and press A + 1 + Z.
    I hope it will work for you!
    Good luck!!!
  • 10,515 Answers
Call 08705 99 88 77 Sony Customer Support.
If it's not registering any disks then it's the blu ray drive thats probably died. Happened to mine on Thursday while playing Fifa 09, rang the number above and Sony are sending me a replacement one tomorrow. Can't fault the service.
Hope you get your sorted. If it has died, you will need to back up your HDD with a memory stick or something. At least make sure your game saves are backed up, the rest you can re download if need be. Sony should deliver a replacement within a couple of days and collect your old one at the same time. Just restore you new PS3 with the data from your memory stick... Thnx.
    President:
  • 2,110 Answers
  1. You have to hold the front power button for about a minute.
  2. hiya, I did the exact same thing, but with a little common sense i finally figured how to get my screen to load again. this is what i did.I went back and plugged in my HDMI cable to the tv it was connected to with the rca cables as well. The HDMI connector should load the screen with its default setting. Go to the settings-display setting-video output setting.change it back to AV MULTI/SCART and just follow the messages. A message will pop up and tell you if the screen goes blank it will reset to its original setting (HDMI setting). Your screen will go blank, in the mean time, change ur television back to either video 1 or video 2, wherever you have ur regular RCA hooked up...you should be able to see the menue. Hit save setting..now ur PS3 should be able to load through the regular RCA cables...hope this help...
  • Sibananda Jena
    Sibananda Jena Dec 29, 2008
    Why don't you reset the setting's back to normal,Just hold the power
    button in for 15 second's until you hear a few beep's it will resta
  • Sibananda Jena
  • 6,487 Answers
Try first to unplug the ps3 from the power outlet for 30 minutes to let it refresh itself then after that check if everything is already working, if still not working a software update will be helpful for this problem,,,
  • Mark Gil
    Mark Gil Dec 29, 2008
    The easiest method is to download the update right on your PlayStation 3. In the Settings menu, right at the top, is System Update. Select this and when asked tell it to Update Via Internet
  • 13,433 Answers
Unplug the ps3 for 10 minutes and try again, you can hold down the power button when powering up the ps3 to restore it to default video settings.
If these two things have no effect I would suggest you contact the dealer and get the ps3 replaced with another one.
On Lego Batman, how do you find all the red bricks
There is one red power brick per level in the video game Lego Batman. This brick will usually be difficult for players to find, but if they do, it will unlock bonus content in the game. The red bricks look like square LEGOs with four studs, and players may easily miss them on their first play-through.
LEGO Batman is a multi-platform video game with a new storyline where lots of villains have escaped from Arkham Asylum and are running rampant around Gotham City.GameTrailers.com: Launch Trailer (Time: 1:00)1
LEGO Batman Fast Facts
  1. Red power bricks are well hidden
  2. Make sure to have the right characters to access the bricks
  3. Finding the red power bricks will unlock content in the game
  4. To see what content the power bricks unlock, check back at headquarters
Hope this works.
Regards,
Anirban Mazumdar
May 16, 2010 | Lego Batman: The Videogame : PlayStation...
While playing the game, it will suddenly make a loud sound the freeze up. What can i do to do fix this?
I have the exact same problem when I play Lego Batman on my Wii. Unfortunately, since the Wii version is the same as the Xbox 360 and PlayStation 3 versions, it has lots of data that the Wii console can't handle sometimes, thus making that loud noise and freezing up. You can't fix it, but the best solution would be to:
1) Unplug the Wii, then plug it back in.
2) Start up the game and try that same part again. It should work. If it doesn't, just keep trying.
*Note: When you plug it back in and start the game again, don't do any other levels before the level that keeps freezing up and making that loud noise. I hope this helps.
Sep 27, 2009 | Nintendo Wii Console
Saved data on Batman is saying its corrupt
you probly upgraded firmware to 3.0 this broke alot of games if you havent already started a new game( this will erase the old saves ) do a system update even if it didnt tell you to, to see if update 3.01 is available. If your already at 3.01 then you may need to start all over or just google ps3 game saves and find one that is about the same level as yours although most are either 50% or 100% complete
Sep 21, 2009 | Sony Playstation 3 (PS3) Console
My ps3 just stopped playing video discs and blu ray discs today. help!
Goto settings at the main menu of the ps3, go to the left to settings, then go down to BD/dvd settings go down to BD 1080p 24hz output and disable it.If this doesnt work out for you call up Sony, theyll get you set up with the repair process. before you call them though, be sure to restore system to default settings, because they will ask if youve done that yet.Their number is 800-345-7669 (800-345-SONY)
Sometimes if you get a blu ray disc outside of your region, then it's not supposed to work. If you live in the US, then only Blu Ray movies from the US will work.
Sep 01, 2009 | Sony PlayStation® 3 (60 GB) Console
I can't get sound on Lego Batman for Playstation 3. Everything else works fine.
Sup, Your problem might be this, theres a scratch on the disk that memorizes the sound. I had a scratch on a game and it froze the game when I pressed play story.
Aug 17, 2009 | Lego Batman: The Videogame : PlayStation...
REPAIR/REPLACEMENT
try going to a game store and asking or look in the manual
May 29, 2009 | Warner Bros. Interactive Lego Batman for...
Ps3-hdmi connection gets cut-off
Again check setting from the menu of your PS3.
Do select reset all factory settings....... Hope this will solve an error based on software. But if still problem persists, call your authorized technician for repairing, because there may be some loose contact with your PS3 or LCD TV.
Apr 20, 2009 | Warner Bros. Interactive Lego Batman
Ps3 parental control
no set it to the highest lvl maxed it gives you total acess then if you set it low thats whats causeing your problem : )
Apr 12, 2009 | Warner Bros. Interactive Lego Batman
I cannot see the whole screen on lego batman for ps 3
You might might want to double check the screen settings for your PS3 to see if the resolution is correct. (ex. if you have a 720p hdtv and it's set for 1080p) it could cause the problem...
Apr 11, 2009 | Warner Bros. Interactive Lego Batman
Lego batman freezes at certain times
princesselis' solution for PC worked for my Wii. When you load up the game, go to options, and change the video settings to vertical (v) sync from off to ON. Works!! Thanks so much!
Dec 09, 2008 | LucasArts Entertainment Company LEGO Star...
Video Game Consoles & Games Logo
15 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
