Question about Cameras
The mode option dial and macro options are not working
  • 4 more comments
  • chris_musgra Dec 29, 2008
    I havde tried re setting and it does not resolve the problem
    fuji s6500,removed batteries and reset, no joy
    Have tried reset
    press reset and ok
    goes to lang option,select english,no message or indicaton to say it has been reset
    If the camera is 3 weeks out of warranty .is the software a big thing or can this be downloaded ?
    is there a download version of the software anywhere ?
    Okay Thanks,Great help thanks team
    Genius:
  • 1,550 Answers
It requires service person to check your camera . Software updating sometimes may solve your problem . If software updating doesnot work then it is hardware fault . You need to contact service person to get it repaired .
Posted on Dec 29, 2008
    Genius:
  • 1,239 Answers
Hi
Make sure you have not set a dial control to say manual focus or Macro focus.
Run through the menu's on the screen to see if you have inadvertantly changed sometihg.
As you are computing - give Pentax Technical Support Team a a go on their website
  • ABHISHEK.C
    ABHISHEK.C Dec 29, 2008
    This is most likely a problem with the dial itself. Generally speaking the software within the camera does not fail unless something breaks within the camera. To make absolutely sure - contact the manufacturer and find out if there is an active recall for this product. If it is a manufacturing or software fault they will recall it. Otherwise it will have to be professionally repaired.
  • 470 Answers
Go to the technician with the software itselfe, and REprogram it because the softwarwe program on it is mismath,, reprogram it...!!
    President:
  • 2,110 Answers
Try to reset to factory default...
  • Sibananda Jena
    Sibananda Jena Dec 29, 2008
    i think some hardware problem..so it is better to contact nearest service center...
  • 10,515 Answers
Reset it to factory defaults and the problem wld be solved.
Thnx.
  • Cameras Master
  • 6,487 Answers
First thing that you can try is to reset the camera to its default settings and then after that check if everything is already working
  • Mark Gil
    Mark Gil Dec 29, 2008
    This a malfunction already on the device that should be handle by tech from a service center since it require already some part replacement....
  • Mark Gil
    you can do a software update for this camera , but since its still new a suggest you have that replace instead.......
  • 13,433 Answers
Start by removing the battery from your camera and try again, also try restoring the camera to default.
you didn't include the brand or model.
well you can get a free repair estimate from  www.advancecamera.com/repair
It does sound like a hardware problem.
  • Ekse Dec 29, 2008
    we can't fix this over the internet, theres a problem with the dial you will have to take the camera apart and inspect it, hows the warranty? if you are outside of warranty I can suggest www.advancecamera.com/repair for a free repair estimate.
When I try to turn my flash on it says macro mode, What is this and how do I fix it?
Macro mode is for taking pictures of subjects very close to the camera. In this mode the flash is disabled.
Without knowing the model of your Digital Concepts camera I can't tell you how to take it out of macro mode. If there's a button on the back marked with a flower icon, press it. Otherwise look in the menu.
Jul 25, 2012 | Digital Concepts Digital Camera
I am using microsoft excel 2007, the code is not running, the macro was disabled.. How to enable the macro...?
From the excel help file
  1. Click the Microsoft Office Button o12filemenubutton_za10077102.gif, and then click Excel Options.
  2. Click Trust Center, click Trust Center Settings, and then click Macro Settings.
  3. Click the options that you want:
    • Disable all macros without notification Click this option if you don't trust macros. All macros in documents and security alerts about macros are disabled. If there are documents with unsigned macros that you do trust, you can put those documents into a trusted location. Documents in trusted locations are allowed to run without being checked by the Trust Center security system.
    • Disable all macros with notification This is the default setting. Click this option if you want macros to be disabled, but you want to get security alerts if there are macros present. This way, you can choose when to enable those macros on a case by case basis.
    • Disable all macros except digitally signed macros This setting is the same as the Disable all macros with notification option, except that if the macro is digitally signed by a trusted publisher, the macro can run if you have already trusted the publisher. If you have not trusted the publisher, you are notified. That way, you can choose to enable those signed macros or trust the publisher. All unsigned macros are disabled without notification.
    • Enable all macros (not recommended, potentially dangerous code can run) Click this option to allow all macros to run. This setting makes your computer vulnerable to potentially malicious code and is not recommended.
    • Trust access to the VBA project object model This setting is for developers and is used to deliberately lock out or allow programmatic access to the VBA object model from any Automation client. In other words, it provides a security option for code that is written to automate an Office program and programmatically manipulate the Microsoft Visual Basic for Applications (VBA) environment and object model. This is a per user and per application setting, and denies access by default. This security option makes it more difficult for unauthorized programs to build "self-replicating" code that can harm end-user systems. For any Automation client to be able to access the VBA object model programmatically, the user running the code must explicitly grant access. To turn on access, select the check box.
Jun 21, 2011 | Microsoft Office Professional 2007 Full...
How do i trun off macro mode?
Macro mode is usually depicted as a flower. Find this option on your camera and switch it to something else.
Mar 20, 2011 | Cameras
How do i use macro i cant find it on the camera does it even have macro
You have macro option. Its the little flower (tulip) on the selector dial).
Full details are on page 5 of the manual
(download free from here)
http://safemanuals.com/user-guide-instructions-owner-manual/OLYMPUS/E-420-_E
Note that on page 109 there are some shooting tips for very close macro.
Hope this helps
Mar 05, 2010 | Olympus Evolt E420 Digital Camera
When i try to turn my flash on it says Macro Mode
You're in macro mode and the flash won't function. Check your manual to find out how to get out of macro mode. Most cameras have a button or a dial with a picture of a flower representing macro mode. Find that and change it.
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
I cannot get super macro mode
Turn the dial- the one that lets you select a mode. You have to be in certain modes to allow for super macro.... (I have a powershot S2) Try AV or manual, or a couple of others. There are a few that will not allow super macro. That's your problem. Good luck!
Feb 02, 2009 | Canon PowerShot SX10 IS Digital Camera
Please help!
Try going into the M(anual) mode on the selector dial and then turn off the flash (press the right side of the controller button until you see the lightning bolt with a bar through it). The macro shooting option should still be available in the manual mode.
Apr 17, 2008 | Canon PowerShot A460 Digital Camera
Focusing
Best way to take macro in DSLR is try A/V mode and switch aperture F value to small value.if you don't have enough light macro need your flash sync.
Dec 06, 2007 | Nikon D40x Digital Camera
Macro mode
The Macro Mode is easily accessed by pressing the second oval shaped button to the left of the arrow pad on the back of the camera. This button is designated by a green colored box with a curved doubled headed arrow – which will rotate the image file when in view mode. The same button also has a flower icon, which represents MACRO MODE when in Shooting mode. Pressing thios button in Shooting Mode displays a menu where you select three options: OFF, Close-Up or Super Close-Up photography.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
