Question about Primera Technology Signature Z1 56300 Thermal Printer
Thermal Printer Language
What language does the Primera Signature Z1 thermal printer require in order to program it manualy or Is there a link to the escape codes required to do this Thanks -pm
  • 4924 Answers
SOURCE: I need a Windows 7 driver for my Primera Signature
if you only see those on the official web site and install the vista driver ...usually the compatibility is around 80% and you have all chances to work ...if it will not ..probably it is not released yet ...But I said for most devices the vista driver work on windows 7..
Posted on Apr 28, 2010
0 characters
1 Points
Zpl emulation with datamax i-4208
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Able Label Systems Thermal Printers
Feb 01, 2013 | Datamax I-4208 Thermal Label Printer
I have a Zebra GK420t Alternately Flashing Red and Green light error message. How do i clear this.
From the owner's manual:
Alternately Flashing Green and Red: Needs Service 8
8. FLASH memory is not programmed.
• Return the printer to an authorized reseller
You can find the complete owner's manual on Zebra's web site.
Jul 25, 2011 | Zebra GK420t thermal transfer and thermal...
Drivers windows 7 printer signature Z1
Here ya go! Here is a link to drivers for both Windows XP and Windows 7. The Windows 7 driver requires a software key. The site indicates that all you have to do is call tech support (number on the site) and ask for a free key. Here you go:
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 24, 2011 | Primera Technology Signature Z1 Printer
What is the difference between the Zebra LP 2844 Thermal Printer and the Zebra LP2844Z?
lp2844 use programming languages EPL2, Line Mode, lp2844 use ZPL II, ZPL (Zebra languages), both are Direct Thermal (don't use ribbon), not Thermal-Tranfer (use ribbon).
Nov 17, 2010 | Zebra LP 2844 Thermal Label Printer
Microwave starts but didnt heat anything
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Aug 18, 2010 | Primera Technology Signature Z1 56300...
Plz send the solution
Try to change printer settings and ensure that you have installed correct printer drivers.
Aug 22, 2009 | Citizen CBM 1000 thermal Printer
I have Thermal Zebra Printer TLP2824, I have installed it and
The printer has firmware TLP2844-Z Zebra. This printer uses ZPL commands and not epl. ZebraDesigner can print to a file and have a format command.
Jan 08, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Can we use any commaon laguage for all Zebra printer.
Can you explain what is is you are trying to print on the label?
May 22, 2008 | Zebra LP 2844 Thermal Printer
Teac p 11/kit thermal printer
This printer appears to be a rebadged Primera Signature Z1, which is the one I have. I went through 2 of them before I discovered that there is a problem with the USB interface inside the printer. If it is disconnected and reconnected, or if the computer is restarted too many times, the USB interface in the printer stops responding. If you unplug it from the computer and leave it overnight, it will work normally again. I believe there is a capacitive circuit inside that is not discharging when it should. I have also been able to make mine start working again by unplugging the USB cable from the computer (leave it plugged in to the printer) and shorting the USB connector with a paper clip. I wouldn't reccommend that to anyone though, it is safer just to unplug it and leave it overnight.
Dec 29, 2007 | Teac P11/KIT Thermal Printer
Primera Technology Signature Z1 56300 Thermal Printer Logo
27 people viewed this question
Top Primera Technology Printers & Copiers Experts
Josh Whitehead
Josh Whitehead
Are you a Primera Technology Printer and Copier Expert? Answer questions, earn points and help others
