Question about Photography
Do not know how to thread film on a Kodascope sixteen-10
Need pictured step by step view of film threading on a no sound Kodascope sixteen-10 with 100-125 volts 1100 watts 1000 watt lamp max made in Rochester, N.Y. U.S.A. Eastman Kodak Company no. 18079
  • Bart Pulverman May 11, 2010
    If you can send me a clear photo of the projectors film path mechanism, I can probably draw a diagram for you.
SOURCE: 1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Posted on Mar 22, 2008
  • 4234 Answers
SOURCE: Peavey 400BH
Thanks for the update. I'll need to look through my records for similar problems. Stay tuned...
Dan
Posted on Jun 13, 2008
  • 1027 Answers
SOURCE: MW8107WA 1000 Watts How do I set the time? .
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
Posted on Jul 13, 2008
  • 4234 Answers
SOURCE: Gem Sound clipping problem
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Posted on Sep 24, 2008
SOURCE: powercord replacement
This is a standard high-wattage appliance cord -- you can find one at any appliance parts store.
Posted on May 29, 2009
How do you load it
To open back cover lift knob on top of camera ( this knob has a small arm that unfolds - used in rewinding).
Once open you will see which side is the film side ( under this knob) and the take up side. On the film side raise the knob again in order to insert film case, the top of this should flip over later used to rewind film. with film trail out toward back of camera. Now push the knob down. Film should only be loaded one way so the knob can be lowered into film canister. Lower knob and Film canister is now secure.
Next thread film leader onto take up spool. Some times these have a slot , but most Just have the teeth that fit the film edge.thread the film into slot then unto teeth. You will need to use film advance arm (There should be an arm on the top opposite side of film knob) you would move that would advance film.
as you move this arm ( with cover open ) film holes should engage the teeth on bottom and top. ( if you can't advance after 1 or 2 advance arm swings) press take picture button ( releases springs).
continue until film is captured top and bottom. Use the film spool knob gently wind film back into canniester until snug don't over wind. Close cover, take a picture with lens cap on, repeat that. As you wind ,the film cartridge knob should rotate.
You are not wasting pictures film was designed for this waste.
you should know how many photos were on film 12/24/36 pictures.
you may have a knob to set to that number.
When your ready to remove film ,push silver button on bottom and use winder handle ,rotating until free and easy. Open cover mention earlier.
wow can't believe I remembered all that and hope that helps.
Sep 23, 2016 | Photography
Seeking archive maint. ops manual for kodak kodascope model 1 16mm film projector
Contact the George Eastman House in Rochester, NY for a possible connection to get a copy of the Kodascope user manual. Most dealers stopped repairing these years ago. Hope this helps !! Jim
Nov 19, 2011 | Office Equipment & Supplies
Kodak 16mm projector
See my other response! Check with the George Eastman House in Rochester, NY for leads on the manuals! Good Luck !! Jim
Can you tell me how to thread a Graphic III laminator?
5-2 THREADING the LAMINATOR
1. Remove the supply roll mandrels and the feed tray. The supply roll mandrels are now ready to accept
loading of the film rolls, wound with the polyester (shiny) side out. When viewed from the front of the
machine, the core grippers on both the top and bottom supply roll mandrels should point toward the
heat shoes (and toward each other). The tension control knobs should be positioned on the right. Notice the
knobs are labeled "Top Right" and "Bottom Right". If you have rolls of film on which the material is wound
in the opposite direction (adhesive or dull side out) exchange the top and bottom supply roll mandrels so
the core gripper positions are reversed.
2. Slide a roll of film onto the top supply roll mandrel, turning the roll slightly to slide the gripper inside the
core. Center the roll. Make sure the dull side of the film is facing up and the shiny side is facing the
heat shoes during the threading. Scored marks on the supply roll mandrels provide a guide for proper
alignment of the two rolls of film to each other.
NOTE: The pointed metal pieces protruding from the body of the supply roll mandrels grip the cardboard core of the film supply roll to prevent slippage. When placing a roll of film on the mandrel, twist the film supply roll to
accommodate easier film loading.
3. With the roll aligned with the scored line on the right side of the mandrel, place it in the top bracket.
Place the left side of the shaft in its slot first then place the right side of the shaft in its slot, turning it as
needed. FOLLOW THE RECOMMENDED LOADING PROCEDURES CAREFULLY WHEN THREADING
FILM IN THE LAMINATOR. ACCURATE ALIGNMENT OF ROLLS WILL MINIMIZE WASTE AND HELP KEEP
THE LAMINATOR CLEAN.
4. While the machine is still cold, review the threading diagram. With the bottom roll of film centered on
the mandrel and the shiny side facing down, run the film under the bottom idler bar and pull towards
you.
5. Load and thread the top roll of film in the same manner as the bottom roll. Refer to the threading diagram. The
film should run under the silver stabilizer bar and over the front of the top heat shoe. Remember, the shiny
side of the film must always go against the shoe. The dull (adhesive) side must face away from the shoe.
Make sure the two rolls are aligned with each other before going to the next step.
6. Turn machine on and heat to the desired temperature.
7. With both rolls threaded and installed in their respective brackets, unwind enough film from the top roll
to reach the bottom of the bottom heat shoe. Next, unwind enough film from the bottom roll to reach the
top of the top heat shoe.
8. Now drape the film from the bottom roll against the film from the top roll on the top shoe. If the laminator is
hot, the exposed adhesive on the top web will hold the bottom web and make it easy to stick the two rolls
together. If you are threading the machine while it is cold, use tape to stick the bottom web against the top
web.
9. Tip the safety shield down into the laminating position. With the film draped over the two heat shoes, push
one edge of the threading card between the heat shoes so that the film is firmly positioned against the
laminating rollers. If a threading card is not available, any piece of card stock or poster board will work.
10. Make sure there is still enough slack in the web. Turn the drive switch to FORWARD, permitting the film and
feed board to pass through both sets of rubber rollers. Carefully monitor initial threading to be sure the web
reaches and passes through the pull (back) rollers. When the threading card has cleared the back of the
machine, move the drive switch to the center position (off). Whenever you want to remove the film and/or
laminated material from the back of the machine, use the zippy cutting tool provided with the laminator.
11. Slide the feed tray into position.
12. If the machine has the slitter option, make sure the slitters are disengaged (blades in the raise
position) and moved all the way to either side of the machine.
CAUTION: The laminator is designed to be run with the operator directly facing the
control panel and feed tray, not at an angle or from the side of the machine. For
operator safety, the safety shield must be in position over the upper heat shoe
when the machine is ON, or when the drive switch is in the forward position.
Dec 21, 2010 | Office Equipment & Supplies
Bell and Howell 16 mm diagram . don't know how to thread the film
Check this Website and see if one of the manuals doesn't give you the answer:
http://www.paulivester.com/films/projector/BH273man.htm
Jul 02, 2017 | Bell & Howell Photography
Under the catagory- Winding Bobbins it says to release clutch holding hand wheel and turn the know toward you. Ours sometimes works and sometimes jams together i.e. won't turn
Hi
You can follow this procedure to wind the bobbin thread--
Step 1--Secure thread on sewing machine as if you were threading machine and pass thread end along indicated thread guides. Thread guides will be somewhat different for bobbin winding than for regular threading.
Step 2--Place empty bobbin on bobbin winding spindle. This spindle will be located on front right, on top right, or on either side of machine. The spindle may have to be repositioned for bobbin winding.
Step 3--Place thread end through one hole in upper portion of bobbin, and pull a few inches of thread through.
Step 4--Disengage the sewing machine needle by either pushing in the center portion of the handwheel or rotating center portion of handwheel towards you. The method will depend on the model of your machine.
Step 5--Take hold of the thread end and pull gently outward so that there is very little slack in the thread. Firmly grasp thread end.
Step 6--Push on presser foot to begin winding bobbin. Hold onto thread end while bobbin is being wound. Wind bobbin only up to guideline marked around the edge of the bobbin.
Step 7--Cut excess thread from the top of bobbin and cut thread that attaches bobbin to rest of thread spool.
Step 8--Insert bobbin into bobbin case, pass thread through indicated slots, and bring thread out a few inches to the right.
Step 9--Close slide plate over thread.
Step 10--Continue threading machine.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 07, 2009 | Office Equipment & Supplies
Threading the bernina 1300DC serger
These things are always complicated when you try to write them down, so I suggest a call to your local Bernina dealer to arrange a quick lesson on how to do it.
If you can go back to the dealer whence it came, so much the better..........perhaps you could go in and buy some things you need and then as you are leaving, make the enquiry with the machine in your car, they may be able to show you how to do it right away......building relationships is a very good way of feeling comfortable about asking for help.
Also..........
If the manual diagram is too small, a local library or stationery supplier should be able to magnify a photocopy for you to see it all more easily.
Jun 04, 2008 | Sewing Machines
Huskylock 910
I received a cd with my machine showing step by step how to thread it. I put the machine beside my computer and threaded it step by step by watching the cd. One problem I had after threading it was not being able to sew a chain without the thread matting up and making a real "mess". The problem was I did not push the thread up against the machine until it clicked. That sets the tension. Try that and if you still have a problem email me and I will try to help. HisOwn2@triad.rr.com
May 20, 2008 | Husqvarna Huskylock Computerized 910
Photography Logo
69 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
