Question about Philips DVDR3370H DVD Recorder/HDD Recorder
Hey There! philips dvdr3370h After 2 years of no problems. disc stuck in drawer - fixed that Now , none of my discs will play. "error - incorrect region code" PLEASE Help! Thanks! Ben.
  • 51 Answers
Try and see if this will work...
1-Power on the player.
2-Ensure disc tray is empty.
3-Wait for (no disc)to be displayed.
4-Enter 0086000 with the remote control ,then press ok.
5-Then enter with the remote control 00009 then ok
this should verify you have region 0
if it does all is ok.
6-Then you need to push system menu button.
7-The first page you come to will be general
you need to change the video output to ntsc,dont worry it will revert back to pal when you exit system menu..and only has to done once to set the hack.
THIS HAS TO BE DONE TO ALLOW HACK TO READ ALL TYPES OF DISCS E.G NTSC AMERICAN.
I hope this helps.
Plz let me know^^ Goodluck!
Posted on Mar 31, 2009
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Nov 24, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
Philips DVDR3370H; DVD stuck in tray and cannot get unit to release
Some types of Philips have a problem opening the tray,the magnet holding the disc at its place is to strong.There is a small hole at the underside where you can put a small pin in to open the tray.The fault usual occurs when there is no disc in the set.
Aug 27, 2009 | Philips Televison & Video
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
DVD won't play
clean the laser lens first
Mar 06, 2009 | Philips DVP3050V/37
New ps2 game won't play on older ps2 game console. Help!?
You're stuck not being able to play, you need to get the slim PS2's because they reconverted the discs for a new disc encoding.
Dec 25, 2008 | Sony PlayStation 2 (PS2) Console
Showing "Disc Error" While playing DVD's
the disc tray is not leveled properly, i had the same problem too and samsung repair centre just adjusted the tray.
Apr 29, 2007 | Samsung HT-DS100 System
DVD recording or playing.
Where can you find the 1-2X DVD, I have only been able to find 1-4X and none of these work.
Feb 07, 2007 | Sansui VRDVD4005 DVD Player/VCR
Televison & Video Logo
116 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
