Amana ALW880WH Top Load Washer Logo
Kent Pavelko Posted on Oct 01, 2012
Maytag washer will hum but not start
It was fully loaded when it stop and out of balance
pixcasey978
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 01, 2012
pixcasey978
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
148
Points
It may have tossed the drum off the rollers. To fix this, you need to take a look at the drum rotation assembly (the rollers that hold the tank you put your clothes in viewed from the outside after removing the back cover) that could be a combination of fan belts and rollers or just rollers that are engaged to spin or agitate the wash cycles. I had the same problem and had her back in line in about 30 minutes of taking the back off, figuring out why it wouldn't spin and setting it back on the caster rollers to function. It's pretty easy to see, good luck!
Out of balance switch will not stop washer when load becomes out of balance.
Your switch is bad. You don't necessarily need the switch. Snip the wires off either side of the switch and fuse them together with a wire connector.
My Maytag washer keeps stopping during its cycle and if I lift the lit it will restart but once it starts spinning it stops. Its weird cuz somedays i can run 3 or 4 loads with out a problem and other...
On older Maytag washers the lid switch doubled as the off balance switch. If the tub wobbled too much it would trip the lid switch and this will not reset until you open the door. The idea is that when you open the door you will adjust the load so that it is not off balance anymore. I don't know if you have one of the models I am referring to or not but if so this is your problem.
http://www.appliance-repair-it.com/clothes-washer-repair.html
12helpful
3answers
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
1helpful
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
1helpful
Front load washer not spinning correctly
IT SOUNDS LIKE THE PAKING STRAPS MIGHT NOT HAVE BEEN FULLY REMOVED, OR THE HAS BEEN A SMALL CLOTHING ITEM THAT SLIPPED THRU THE OPENING WHEN YOU OPEN THE DOOR THERE IS A SEAL AND IT IS VARY FLEXABLE SOMETHING COULD HAVE GOT THRU, BUT IT STILL SOUNDS LIKE THE PACKING STRAP WAS NOT REMOVED ALL THE WAY IT COULD HAVE BROKE OFF WHEN BEING PULLED OUT, IT'S JUST A PLASTIC STRAP BUT MIGHT HAVE TO REMOVE THE FRONT COVER TO GET TO IT,
2helpful
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
1helpful
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Maytag mah4000aww trys to spin shakes and stops
there are off balance switchs on the tub that will turn it off But if the pump sump is full it will pump slow and throw it off balance so check to see how well and fast it is pumping the water out
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
