Question about Dell E172FP 17" LCD Flat Panel Monitor
Blinking monitor power button and flashing image
I have a dell e172fp 17 inch . suddenly when I tried to wake it up from power saver mode, it flashed a second and went blank. it keeps blinking green light on the power button. the monitor blinks white once in a while. when i press the power button hard, it shows the screen once. Does anyone know what is the reason for this problem ?
  • 1 more comment
  • ajv75 Apr 14, 2008
    I have a Dell E152 FPb monitor that is doing the same thing. Works fine as long as it is stays on. If the computer goes into sleep or hibernation mode, the monitor will not come back on when I try to wake it up. Power light blinks (green, orange, off, green, orange, etc.) and then the screen blinks with dark lines and eventually goes off. Pressing the power button does not do anything. Only way I've gotten it to work again is to unplug the power cord in the back of monitor. Updated Video driver, but same problem happens again after hibernation or sleep mode. Any idea?
  • Wilkerson May 02, 2008
    Yes, I am having the exact same problem and can't afford to repair it. Any suggestions would help. My screen is just blinking out. It'll come on fine when I turn it on for 2 seconds then goes out again. Why is this a recurring problem. I have had the monitor since 2005.
    -Theresa
  • jacklang116 Sep 08, 2008
    I am working on a friends monitor and am having a similar issue. The screen gets power and then consistantly the power light and the monitor flash on and off every second
  • 4 Answers
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Posted on Sep 12, 2008
I bought the parts (6 transistors, 1 fuse) on ebay (http://cgi.ebay.com/DELL-REPAIR-KIT-E152FP-E153FP-E172FP-E173FP-E173FPB-/220488756040) and put them in. On the ebay site it also says make sure to resolder the transformer joints. When I turned on the monitor the color bar screen appeared in the bottom left corner for about 3 seconds and then disappeared. Then the power on LED started blinking again - back to the original problem. I'm going to attempt to resolder the joints. Any more suggestions from anyone with experience fixing the problem?
Posted on May 19, 2010
3 monotors with the same problem???
Posted on Sep 22, 2008
I bought a new acer 19" . i will try to change the capacitors and see how it works. if not, i will try the power inverter option. but my new lcd itself cost me 100$ after rebate. so paying 70 pounds for an inverter is unwise. previous poster, I am sure it is problem with monitor and not the connector coz it doesn't do the self diagnosis. thanks for all the responses so far.
Posted on Jun 12, 2007
Hi, I belong to another group, and posted this same question, due to an E172FP that I bought knowing it was faulty. The person who answered my post stated that he had just been doing a study on this because of a customer. Apparently it is quite common with this model. The monitor is made by samsung and is good so I'm told, but the electronics is made by another company and this is prone to failure. The part in particular, according to the respondant, is the power inverter and he believes it could cost as much as £70. I have seen some inverters on ebay going very cheap. I hope the info may help.
Posted on May 07, 2007
I HAVE HAD THE SAME PROBLEM WITH MY MONITOR. i HAVE NOT CHANGED ANYTHING WITH THE VIDEO CARD AND HAVE TRIED THIS MONITOR ON MY OTHER COMPUTER AND DID THE SAME THING! UNFORTUNATELY, I THINK I HAVE TO GET ANOTHER MONITOR.
Posted on May 06, 2007
    Brigadier General:
  • 6,966 Answers
Hi,other than suggest that you bring bring it to a qualified service personnel, the problem is might be too techincal and is inside the LCD monitor itself. Just to be sure, check that all the plugs and connectors going to the monitor are tight and secured. Wiggle it just a bit to make sure all the pins are seated. But then again, might it be your PC (video out). Try shutting down, reboot/restart. If this still doesn't work, try restarting in safemode (press F8) while booting, then start again in normal mode. If still no go, guess you're back to the first paragraph. Good luck. Hope this be of some help to you. Pls post again how things turn up.
Posted on Apr 28, 2007
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
Feb 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My monitor keeps going into power save mode
Its not power saver mode, when the display goes black and the power light starts flashing that is a good indication that the power supply is about to die. The Dell E172 monitors are noted for this problem. We have step by step repair guides posted on our web site at: www.ccl-la.com Click on the monitor repair link. The Dell E172 series actually has several sub models, check your specific model, the sticker on the back will have either E172FPb, E172FPc, E172FPf. We have guides for all 3 versions posted.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 30, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Press power on... screen flashes on (blink), then goes blank and power button flashes
dpelrod727, Yes, the "switch-mode-power-supply" is in "partial" or "full" SHUTDOWN mode. Reconnect E172FP to a fully booted KNOWN good PC with the win-desktop as the displayed screen. Check with flashlight to see if your LCD panel is both BLACK and BLANK, or just BLACK by holding a bright flashlight 1" from screen at different angles even though the screen appears to be blank. If very faint image of desktop is seen then your SMPS is still half alive. Here are your options in either case. 1. Trade in for new. 2. Try Dell for a cash+old swapout for a Refurbed unit. 3. Check out www.ccl-la.com/badcaps, www.badcaps.net, www.lcdparts.net, and YOUTUBE long video clips dealing with LCD monitor disassembly and LCD repair. could be helpful in making decision on what to do. I'm 12fixlouie If this was helpful rate on fixya.
Nov 01, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
Dell e172fp flat screen
check the power if 110 volt or 220 volt
Jun 05, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Unable to get monitor out of power save mode
turn your moniter off waite 30sec back on this should get your screen on. Try this Rigth click on your desk'top >properties
>screen saver, click Power then change the turn of monitor tab
Jan 24, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell computer windows xp pro. samsung syncmaster 731b cannot install right. says comp. cannot support default monitor installed ,
I need help monitor went blank and when I try to turn it back on it only blinks at the power button. took it apart and everything looks ok.
Mar 26, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
1,252 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
