Question about Philips HTS 6600/12 Home Theatre System HDMI Theater System
HTS3548w/98 Hi, When i plug in my Sandisk USB 4.0 GB drive to philips HTS3548w/98, its unable to detect it. Is there any specific settings that needs to be done. Thanks for the help.
4 Suggested Answers
rodamo
  • 224 Answers
SOURCE: dvd player is in region 3 need multi region for model philips hts3548w/98
Brand and model?
Posted on Jul 15, 2008
  • 349 Answers
SOURCE: ''WRONG REGION'' MESSAGE ON PHILIPS HOME THEATRE SYSTEM
Ensure both TV & player are on , no disc in player
on the remote press: disc menu, then open/close then stop
enter the following numbers:
7,3,4,4,6,6,0
you should see region 0 in the bottom left hand corner
the player should now play, if not and your in Australia ring Philips on
1300 363 391
good luck
Terry
Posted on Jan 12, 2009
  • 133 Answers
SOURCE: hts3440 home theater 5.1
Check the file system format on the flash drive (possibly FAT32) and have the hard disk drive formatted with the same file system.
Note that Windows can not format with FAT32 any hard drives that are bigger than 32 gb, you will need to do it in MAC OS or in other operating systems that support formatting large hard disk drives with FAT32.
regards
Posted on Sep 18, 2009
Testimonial: "thanks , let me try to format it. thanks again!!"
My pc doesn't show sandisk cruzer blade 4 gb pen drive whereas it shows others
Sometimes, windwos OS, give same drive letter to different devices, and when you connect both, one is not showing. So, you need to go in to Disk Manage (right clic on "My PC", clic on Manage") and verify if you can assign a different driver letter to your pen drive.
Oct 01, 2012 | SanDisk SDCZ50-004G-P95 4GB Cruzer Blade...
Not detected
1stly try the Kingstone in another PC - if it works in another PC you have 1 of 4 problems:
1] You are using a very old version of Windows and therefore would require drivers for the memory stick. (i.e. Windows 95 or Windows 98)
2] Your USB ports are faulty - try the ports at the back of the PC instead of the ones in the front if you have not done so already
3] There is a virus on your memory stick and it is attempting to load an executable file when u plug it in and that is causing it to fail.
4] It is detecting fine but you cant read it because the FAT (File allocation table) is damaged in which case it will need to be formatted.
I will need some more info though - for example:
Does windows say "Hardware detected" when u plug it in?
Are you getting any lights flashing on the memory stick?
What do you see when u click on my computer? Does is show up at all but u just cant open it?
Good Luck
Feb 04, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I need to remove some photos from an old computer. Windows 98;. Is not able to be connected to wireless internet. I bought a Cruzer Blade USB Flash Drive 4 gb. Will not work. As I cannot download a...
If the Windows 98 computer does not have a USB port and you cannot copy the photos onto a floppy disk or burn the photos to a CD then the only option is the following.
Remove the hard disk and connect it to a USB hard drive adapter and then plug this into a USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and copy your photos to this computer or to a USB flash drive.
Oct 07, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
4 Gb pen drive can't poen
Your drive could be corrupt. The first thing I would do however is make sure you are plugging it into a good USB port. If you are using a desktop with USB ports in the front, and are plugging the drive in there, remove it and plug it in to one of the USB ports on the back of the computer. Many times the front ones will have issues with certain USB devices. If that doesn't work, you very well may have a bad usb drive. I would try it on another computer if switching the usb port doesn't help, to see if the drive is truly not working or just a driver problem on your computer.
Apr 20, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
4 GB sandisk pendrive can't open
1. continue without solving
2. If you didn't remove the drive with the safe removal tool in the task bar ( lower right hand corner) the drive will lose it's ability to be mounted or seen by Windows and will not format. You will lose data.
Apr 20, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sansa mp3 player not detected by system
1. I assume you are using a USB Port to connect the device?
--Yes - Continue - If No, please specify connection method
2. Does using another USB Port on the PC make any difference?
--No - Continue - If Yes, that port on the PC is not functioning.
3. Are other USB devices that you plug into the PC detected?
--Yes - Continue - If No - the USB system on the PC is not functioning - upgrading or reinstalling the driver might work if it is not a hardware malfunction.
4. Did you install any type of driver for the Sandisk mp3 player?
--No- Continue - If Yes - uninstall and reinstall the driver.
5. Do you have another USB cable to try with the device?
-- If No, try another PC.
CL23
Feb 15, 2008 | Computers & Internet
Pen Drive Driver
You must install a "Driver" for it to work under Win98, go to the manufacturers web site and download the driver and install.
Feb 07, 2008 | SanDisk 8GB microSDHC Memory Card with...
Win98se i did it ... HERE'S HOW
OK, I bought this Western Digital MyBook 500 GB Essential Edition too, and could not get it to work with Windows 98 SE.
I followed the above instructions, but my version of windows was missing even the drivers suggested above! UGH!
HOWEVER, I found ANOTHER SOLUTION. I installed USB 2.0 drivers for mass storage and the the MY BOOK icon popped up on my Windows 98 SE machine. Hurray! Hurray! Hurray!
Here are the drivers from this british webpage:
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Good luck to all you frustrated folks scooping your info off Windows 98 machines!
Dec 29, 2007 | Western Digital My Book Essential Edition...
Philips HTS 6600/12 Home Theatre System HDMI Theater System Logo
115 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
