Question about NAD C370 2-Channel Amplifier
No power at all on NAD C370
Hi
I've had my NAD C370 for years and just yesterday when I turn on the power button, nothing, its absolutely dead, no lights, no noises, dead to the world.
I've read through some articles in this site and I'm still unsure how to proceed. Is it the internal fuse? or something else?. If it is the fuse what's it specification and where would I get one just to give it a try. I phoned the local shop I bought this from and all they can do is return the unit to NAD who will charge £150 just for looking at it.
I'm no expert in electronics but I'd rarther have a go at something than just hand over money to NAD with no real idea whats wrong.
Thanks for any help.
  • stevee_carr Jan 01, 2009
    HI
    Thanks for replying, I appreacited the advice. I managed to fix the amp. It turned out it was the internal fuse, the confusion came from the supplier had inserted a 4a fuse from manufacture and it turns out I needed a 6.2amp to be replaced. Anyway its all sorted, thanks for replaying so quickly.
  • 24 Answers
User manual here
http://nadelectronics.com/img/manual/NAD-C370.pdf
Read page nine for some simple troubleshooting tips and see if that helps.
It *could* be a fuse but given you've owned it for a while and NAD amps often have capacitor issues in the power supply, chances are it needs some serious work by a good tech. Contact NAD directly and see what they recommend.
Posted on Dec 29, 2008
NAD C370 distortion
Check first if you got +68/-68V on amp module left and right on contact CZ302 and CZ402 pin 2 & 7. Often the -68V is missing. This is caused by faulty transistor Q713 in +68/-68V power supply. It's a 2SA872.
Oct 31, 2013 | NAD C370 2-Channel Amplifier
Nad c370 keeps switching off
Check the speaker wiring for shorts, a common problem. If everything checks out there may be bad solder joints on the main board especially in the output stage, or there is a fault in one or more driver transistors.
Jun 02, 2012 | NAD C370 2-Channel Amplifier
Nad c 370 no power
You need to look inside. There will be a fuse inside too. If your lucky it will restore the amp once replaced, but if it blows again you have a fault. You can track it down yourself if your any good, you might even see a burnt out part when looking for that fuse, otherwise get the repairman in.
Sep 20, 2009 | NAD C370 2-Channel Amplifier
Knob for NAD amp?
Hi...
try your "local" NAD seller and ask them?
Contact NAD by email.
or
www.audiokarma.org
100's of users someone there should be able to help.
Jan 11, 2009 | NAD C370 2-Channel Amplifier
HELP PLEASE. NAD 370 JUST DIED...
This could be as simple as a bad connection at the voltage regulator IC or blown output transistors. If you have a multimeter and some experience with electronics repair, this should be fairly straightforward.
Let me know and I'll try to walk you throught the repair.
Dan
Sep 07, 2008 | NAD C370 2-Channel Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
NAD C370 in protection mode
With closed eyes -replace all capacitors on protection PCB All of those caps are overheated and dry out (they lost there capacidance).Note that capacidance meter will not help you at all. Now unit will work. BUT!!! Most important!!! Check four big filter capacitors in the middle of unit!!!! If they are white (NAD 10000uF/80V) DO NOT USE UNIT AT ALL!!!! FIRE HAZARD!!!!! Contact me... Dariusz
Dariusz70@verizon.net
Feb 10, 2008 | NAD C370 2-Channel Amplifier
NAD C370 2-Channel Amplifier Logo
1,076 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
