Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Isn't spraying I have a bissel prosteamer and it is not spraying when it on the floor unit, Ive tried to find a block but i can't find any...what do i need to do?
    Scholar:
  • 33 Answers
Mine does that, too. Pushing down and wiggling the tank usually gets it going. Also, it doesn't seem to work when the soap bottle is low, even when the soap is turned off. I fill the bottle with water. It is easy to take the top off. Mine has just 6 screws. Then you can see all the tubing and parts. For example, you can unclip the nozzles and see if water flows. Try blowing through the nozzle to see if it is plugged. Some people say the heating unit in the handle plugs up, particularly if you put soap in the water tank. I haven't dealt with this, but it should be easy to open the handle and bypass the heating unit.
Posted on Sep 11, 2007
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
How to trouble shoot and repair at home Bissell proheat 2X water will not spray from floor nozzel ?
Check your User's Guide. Cleaning the filters may do the trick. Contact Bissell Consumer Care at 1-800-237-7691
Sep 17, 2014 | Bissell Vacuums
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
Bissell 9500 proheat 2x wont spray liquid to the floor
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghhdg
May 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell spray to floor not operating. Spray to upholstery fine.
heatman101
urr
Jan 01, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat only sprays for a few seconds.
When was the last time you changed the flat belt? Even if it isn't broken it could be so stretched out that when the brush hits the floor it slows or stops the pump from spraying. If its a new belt then and your sure there arent any clog's that usually means the pump is bad. Also if youve ever used anything other than bissell shampoo in the machine it could have ruined the pump as well.
Sep 15, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
