Apple AirPort Extreme Base Station 802.11g/b Logo
Posted on Dec 29, 2008
Imac AirPort Extreme (0x14E4, 0x8C) to wifi
I have imac built in AirPort Extreme  (0x14E4, 0x8C) and a gateway windows based laptop n i want to set up a wireless connection between them with out a router. my windows machine can detect imac but imac can't detect wifi
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Aug 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
6298
Points
11
On the iMac choose Create Network... from the Airport menu. Then the Gateway laptop will be able to join the iMac's created network.
macs2u
How can I connect my Imac with my Toshiba hdtv Series V4210U via airport extreme?
Does your Toshiba have a wireless adapter? If so, you can set up a home network, if you don't already have one. If no,Does the iMac have a VGA or HDMI connector? You can connect via a adapter cable, Vga to HDMI or a HDMI cable, depending on the iMac connections.
MA073LL/A wifi but no internet
Thanks Habour castl for letting us and future people having a similar problem know that the firewall settings was the cause of the internet not working through your router.
Apple airport extreme stopped sending out a signal. no wifi pick up on any comp phone or ipad light is flashing amber. did a reset unplugged rest again noting
Go to your Airport utility, if you do not have it. download it in the app store. use the wizard setting, it will find your probles
Not connecting wirelessly to mac
Thank you for contacting Fixya Support, I am glad to assist.
Depending on what type of Internet service you are using, your Intel iMac comes standard with an Airport Extreme wireless card built in. As a result, if you are unable to connect wirelessly to the Internet, you will need to try this:
- Click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences from the drop down menu.
- Now locate Network from within System Preferences.
- In the side window, make sure you see Airport and check also to see that it is turned on. If it is, then check the left side window to see if the AirPort connection is active.
Keep in mind, your modem or connection router of course, has to be able to provide wireless connectivity, otherwise, if you do not, there will be no need to try connecting via your AirPort Extreme card.
If your network has been physically set as a wireless network, then just turning on the AirPort card in System Preferences>Network will start discovering all networks within its range, including your own network.
So whether you are using an Airport Extreme, Express or a 3rd party (non-Apple-branded) router, you should be able to connect wirelessly.
If you are still unable to connect with these basic steps, here are a few articles you will need to review from Apple Support informational database:
Requirements for wireless Internet access with AirPort
Airport & Bluetooth interference (for connectivity issues)
So here are some basic steps and resources you can try.
If you have more questions please feel free to post a comment.
I hope this information helps.
Regards,
-Mactechtrainer
All of a sudden the light on a airport extreme is blinking green.
That is the standard for the airport extreme indicating that it is operating properly. If you go to applications and then utilities open up airport utility. Click on your airport in the left hand box then click on manual setup then on base station and then click options under status light you can then choose either flash on activity or always on (which is the default).
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Apple Extreme Network not picked up by Windows XP laptop.
it's a matter of who did what with whom and when they did it.
Vista came along when Apple and Microsoft had agreed to allow each other OS's to operate in each other's platforms with Intel performing the Core Duo marriage, but XP is the child from a previous generation when the two did not get along, though they knew of each other.
I know some actual marriages like that.
Didn't mean to be flippant, but XP is better than Vista in some respects and worse in this case.
4answers
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Wireless Modem don"t connect
well imac G4's don't  have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card  then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
