Question about Earthquake Sound SZ-12 Car Subwoofer
What is the box space requirement for a 12"sws 600 w car subwoofe
I may have the wrong box
  • v2design Jan 08, 2009
    can i used a bit of 12'' pvc pipe half ins'' thick to make a box or enclosere for my 12'' earthquake subwoofer MR kent.
  • 74 Answers
- 1200W peak
- 1000W RMS
- Recommended sealed enclosure range: 1 to 2.0 feet cubed
- Over 4" long throw excursion
- 3" High Temp flat wire dual (2x4ohms)
- Dual Nomax / Romax spider construction
- 8 gauge speaker connections
-Mounting Depth 7.25"
Posted on Dec 29, 2008
How many watts is these woofers?
Manufacturer Alpine Wattage 600 Watt Speakers Format Round Active / Passive Speakers Passive Speakers Installation Built-In Category Pair of Speakers, Subwoofer Number of Ways 2, 1 Size (Diameter) in mm 250 EAN 4958043515356
Sep 30, 2010 | Alpine SWS-1040 Car Subwoofer
Can you hook up two 12 inch subs to a 1000 watt amp?
need more info well you need to look at the subwoofer and see how many watts it can take and if it 2 ohm or 4 ohms single or dual voice coils and on your amp is it mono or 2 channel and what is the omhs for it
Mar 11, 2010 | Alpine SWS-1223D Car Speaker
Need dimensions for 12' 450watt IMPP Subwoolfers for proper air space
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 200mm, depending on the frequency of bass you require.
On a 12 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Oct 14, 2009 | Car Audio & Video
What enclosure do i need for cerwin vega v-max 124 12" sub
Just get a 12" sub box enclosure for an audio store near you or make a custom box, a larger box supposedly gives you more bass yet at the cost of boot space. I have a type R sub and the box is only as big as it needs to be for the sub to fit and it gives amazing bass.
Aug 04, 2009 | Cerwin Vega V-Max 12 Car Subwoofer
System cutting out
Pull the subs out of the box and check the connections... Check to see if the wires running from the connectors on the sub itself to the voice coil... had a JL 10 that had a frayed wire to the voice coil system would cut in and out. Hope its helpful
Mar 30, 2009 | Alpine SWS-1240 Car Speaker
I would say look for a custom box off ebay or build one behind rear seat. Im not shure if you can fit a small truck box behind there but you may be able to. It would sound pretty good behind rear seat. Hope this helps
Jan 13, 2009 | Pyle 12" 600 Watt Amplified Subwoofer Tube...
My subwoofer stops when volume is increased
have u check the radio out do u have an eq
May 19, 2008 | Kicker CVR12 Car Subwoofer
RE: ntx-6612
hi, if they are 12s then give them 12 iches in depth and 14 inches on with,same with the hight
Feb 21, 2008 | DHD NTX-6612 Car Subwoofer
Earthquake Sound SZ-12 Car Subwoofer Logo
120 people viewed this question
Top Earthquake Sound Car Audio & Video Experts
Tom Chichester
Are you an Earthquake Sound Car Audio and Video Expert? Answer questions, earn points and help others
