Lost user guide - can you help
You can get the user's guide here: http://www.lexmark.com/publications/pdfs/2007/4300/winug/en/frameset.html
SOURCE: Need Lexmark P4350 driver cd Computer has no
go to www.ebay.com
and copy and paste this number 150347337171 in the search area. There is one there for sale, a CD for 14.99 Good luck.
SOURCE: lexmark p4350
as you didnt post your operating system, go to the link below and choose it http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0
SOURCE: error 2200
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply from the back of the
unit.
Open the scanner cover. Check the scanner glass for cracks and
the scanner casing for cracks. Close the scanner lid.
Open the top
cover of the AIO.
Using the carrier belt, move the cartridge carrier to
the middle of the unit.
Remove both cartridges, close the top cover,
reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
unit.
Open the top cover of the AIO.
cartridge carrier to the middle of the unit.
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on
the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Maggie B
SOURCE: have lost installation CD for lexmark P4350 all-in-one
I have a link for you, now you can download Driver for your Lexmark P4350 Printer from this website.
http://www.nodevice.com/driver/P4350/get45370.html
Thanks, for trust on Fix Ya Family.
If it work, donot forget to Rate this solution.
Thanks.
avastph
SOURCE: lost software disk for lexmark p4350. got new computer
please you go the your printer's autho. dealer and give a printer brand name and number and cullect a printer driver original cd and instoll a your new pc. and save second copy driver and printer progrmmas.
