The Fizz Book use the Windows XP operating system, so essentially it should start-up the same as any other Windows Laptop. Either there is truly no operating system installed (these things happen with any mass production at times), which I doubt, or the BIOS can't find Windows to load it. I would first go into the BIOS set up and make sure that it's set to boot from 'hard disk drive'. When you first power on the laptop, watch the bottom of the screen to see if you get a menu then press the appropriate 'F' (function) key, F2 on my Toshiba laptop, then hold it down until a set up screen appears. If you don't get this first menu, the screen that says 'no operating system' may have a set up option.
When you get to the BIOS menu choose 'Boot', then make sure that it is set to boot from 'hard disk' .
Personally though, I would go to the store where you bought it and demand an exchange before doing anything. There is just no excuse for this to have slipped through quality control and making it's way to a consumer. If you have other questions, please contact me. Good luck!
This error message may appear for one or more of the following reasons:
Use one of the following steps to resolve the error:
Step 1: Test the Hard Drive
Use the steps below to test the hard drive in a Notebook PC using the Hard Drive Self Test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed.
If any test fails , contact service cente and support for instructions on how to order a replacement hard drive.
If all the tests pass , press the power button to restart the PC. If the error still occurs proceed to Step 2.
Step 2: Repair the Master Boot Record
The Master Boot Record (MBR) is a section of the hard drive that is used by the PC to start the Windows operating system. If the MBR is corrupt, the PC will not start. The Windows Operating System Disc (OSD) provided with your HP notebook PC can be used to repair the Master Boot Record (MBR). Follow the steps below carefully to repair the MBR.
NOTE:
For more advanced information about using the Windows Recovery Console see Microsoft: Learn more about the Windows Recovery Console (in English).
Step 3: Reinstall the Windows Operating System
U may directly visit microsoft website or use the disk.
Thanks.
The above procedure is applicable for all laptops :)
Take care.
Ba bye.
Ways to install windows xp :0
http://support.microsoft.com/kb/316941
Thanks.
It telling us exactly that the system cannot detect any operating system on your hard drive, so what you can do here is to run a XP installation cd or any operating system installation cd to install a operating system on it..
what leads do I need to connect the fizzbook to my pc so i can install the windows disc provided?
