Question about Indesit Washing Machines
Black mould round door seal - Indesit Washing Machines
  • Indesit Master
  • 3,463 Answers
There are several reasons for this to happen.
the primary one is the fact that you are doing a lot of low temp washes, and this causes a build up of grease and dirt around the door seal, the mould you refer to is actually bacteria.
You must do a high temp wash at least once every 6 to 8 weeks, put powder and or detergent in as usual, but no washing, and let it do a full cycle.
This is called a maintenance wash and helps prevent what has happened to your m/c.
Thoroughly clean the door seal with a scouring pad or stainless steel wool, you will not harm the seal,
You will probably find the seal will be stained, but as long as you get all the mould etc off, it will be o/k.
Plz rate my solution.
Posted on Dec 29, 2008
  • Rick Tylka
    Rick Tylka Nov 29, 2013
    This was very helpful.I never used any hot water before. I still have to see how to replace the seal as I have remove it already.
How do i clean Bosch WAE20261AU front loader washing machine
The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
Apr 27, 2013 | Washing Machines
My maytag neptune washer has black residue on the seal. I have tried everything & nothing seems to take it off. I am now concerned that it is mold. Has anyone experienced this same problem?
Hi just read your posting.The black residue is most likely mould.I have seen it on a few front loaders.Have you tried the product called Mould off ?It helps on some machines.Worse case you might have to replace the door seal.Please reply for further help.Looking forward to your reply.
Jun 24, 2012 | Maytag Neptune MAH6500A Front Load Washer
The round gray rubber seal that the door shuts into between the door and the clothes spinner is collecting mould/greese everywehere. How do I clean the problem up and stop it from happening?
The rubber seal is already loose and degrading which causes the dirt, it needs to be replaced... the replacement is tight... have it checked by a technician to replace it with a new one.
please rate..
Jan 31, 2011 | Washing Machines
Black mould
this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
May 13, 2010 | Zanussi ZWF1440 Front Load Washer
Mould/gunk on the rubber seal of a Maytag MAF1300 AAW - help!
Once mold is present the only way to get rid of it is with peroxide. Any residue left will grow again.
May 13, 2010 | Washing Machines
We have a Fridgedaire front load clothes washer and we would like to know how to get rid of the mildew on the front seal?
be carefull what chemicals you use on the door seal,get in touch the manufacturer or call the appliance guy that sold it to you
Jan 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Sep 08, 2009 | Washing Machines
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Zanussi front load washer door seal
Keeping the door open after your wash would help in keeping the interior dry. Do not push the door shut, just leave slightly open. Only before you begin your wash, check to see your cat is not inside.
Oct 13, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
510 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
