Question about Mitsumi (KFK-EA4XT) Keyboard
On startup my keyboard doesn't work
Every time i turn my PC on i need to unplug and then plug back in my new mitsumi keyboard to make it work.. i dont know what is the problem
  • Anonymous Jan 30, 2009
    i'm using wired keyboard
  • 8,637 Answers
Normal 0 Do you have a wireless keyboard?
Press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver. Then you should not have to disconnect and reconnect the plug.
Hope this helps. Bud
Posted on Jan 30, 2009
Keyboard doesn't work
To determine if the motherboard is faulty, connect an USB keyboard to your laptop an see if the keyboard works properly. If so then the laptop keyboard may only need the keyboard connector unplugged and then plugged back onto the motherboard.
Nov 29, 2012 | Gateway NE56R10u Laptop
Computer doesn't recognize ez eyes keyboard
unplug the keyboard, go to the manufacturers website and download and install the drivers, plug the keyboard back in.
If that doesn't work
check your device manager and see what keyboards are in the keyboard section. delete anything but the hid keyboard device and the standard ps2/2 keyboard from the keyboard section. repeat the first set of instructions
if that doesn't work either
take the keyboard back it is most likely faulty
Aug 25, 2012 | Toshiba Computers & Internet
My keyboard is frozen. its not the first time. i dont know if its a usb keyboard
You might need to get a new keyboard.
You can tell what kind it is by looking at the plug where it plugs into the back of the computer. If it is round then it's a ps/2 keyboard. If it's a tiny rectangle then it's a USB keyboard.
When you figure out if it's usb or ps/2 you can get a good deal on a new keyboard here:
Jun 25, 2012 | E-Machines Computers & Internet
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
Why do I have to unplug and replug the USB every startup?
Because you have to set Digital Driver Signing to OFF EVERY-TIME you Boot your PC this is because the drivers are NOT "Official" Windows certified Drivers. You need to press F8 EVERY-TIME you boot your PC and go to the bottom of the list and select to turn OFF Digital Driver Signing before ANY drivers will work, if they are NOT certified.
Feb 20, 2010 | Computers & Internet
Hye i have a mother board asus p28-f and every time that i start my pc it shows, keyboard error or no keyboard present keyboard is locked out- unlock the key. i can't even get into the bios. does anyone...
Are you using a USB keyboard? If so, try a different USB socket on the back panel of the motherboard.
Some motherboards can use a USB keyboard in the OS, but do not recognize it on startup; they only look for PS/2 keyboards. If you can get into the BIOS, you may find a keyboard startup option that lets you adjust this behavior.
If you are using a known good PS/2 keyboard, your keyboard jack may be worn out or broken. If you have unplugged the keyboard and plugged it back in just before you started having problems, unplug the keyboard and look inside the plug for bent or broken pins. PS/2 connectors are really nasty about being forced in at the wrong rotational angle.
Worst case, and least likely - the keyboard controller chip is not working.
Aug 28, 2009 | ASUS Computers & Internet
Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
Good Luck!!
May 19, 2009 | Dell Computers & Internet
Hello iko_gan,
This is actually a problem with USB Keyboards, Make sure that your BIOS is set to boot with USB making USB part of the boot sequence as opposed to an OS driver driven function, and if possible use the USB 1 port and not the USB 2 port. USB 2 is more suited for Hard drives. and why use all of your USB bandwidth for your key board.
This helped me solve my problem in this area.
Mar 28, 2009 | Computers & Internet
Brand new Mitsumi internal floppy drive not recognized by Windows
Check the BOIS setup. Press on boot and see it the Floppy drive is turned on.
Mar 05, 2009 | Mitsumi (D359M3 SILVER) Internal Floppy...
Does not work nor does a new one
Thank you for your response. I just went ahead and bought a USB keyboard and that solved my problem. Thank you once again.
Sep 26, 2008 | Gateway 2520915 Keyboard
Mitsumi (KFK-EA4XT) Keyboard Logo
126 people viewed this question
Top Mitsumi Computers & Internet Experts
David Payne
David Payne
Are you a Mitsumi Computer and Internet Expert? Answer questions, earn points and help others
