I can not format my sony walkman,it switches on and then off
When i format my sony walkman NWD-B105 the message unable to complete format pops up.Also when I switch it on,walkman appears on the screen and then switches off
This can happen when the file system gets corrupt, what I would suggest you is to connect the device to your computer via a cable and then check if you can find the music files in it.
When you do that , you should copy the files to your computer and then format this music player and then again copy the files in it.
This should solve your problem. In case it does not , feel free to contact me.
there is a rest button at the backside of the walkman.put a needel there and press it...your walkman will be turned off.now on it again it will start working as it was before
I am not able to switch on my NWDB103/F mp3 player. Can anybody will help me. I went to Sony service center they have suggested to charge my mp3 for atleast 8 hours. After doing the so still the problem occured.
i have a problem when i start my mp3 it gives format error even i have formated my mp3 but it's giving me the same error please tell me its solution...
I had the exact same problem with my girlfriends sony nwd-b105 mp3 player. I fixed it by downloading the firmware version 1.2, which can be found here at the sony support link below.
- Backup your mp3 files
- Make sure your mp3 device is NOT plugged in
- Run the firmware executable
- When it asks for it plug in the mp3 device
- Check option: format data area
- Press Start
- When finished, take the mp3 device out and press the power button
- If everything went well it is creating a database again and will function correctly as usual
- Copy your mp3 files back to the mp3 device
- Enjoy your music again!
Had a similar problem with the B103F. Not sure it will work for the non F version. Goto Sony's support site at http://www.sony-asia.com/section/support. Search model - NWD-B103F (non F is not listed) Look at the "latest downloads" and select the "firmware update program". (alternately you could first select the "download" section and then select the model.) Download. Run (without the unit plugged) and when asked plug the unit. To be on the safe side, ask it also to format the data section. When finished, the unit should be OK.
