Question about 872 Responder LE Security Remote Start
2way remote for Python 872 not working
Hello, my Python 872 responder 2-way came with two remotes. A 1way and a 2way remote. They both ran out of batteries, so i replaced them. The one way remote works great, however the 2way remote does not function correctly. It can't arm or disarm my car. It would be much appreciated if someone could help!
  • brandondle1 Jan 26, 2009
    i have the same problem. my 2 way python 872 remote does not work after same type battery replacement. please help us sove the prolbme. thank you
Make sure that the responder is set for your car. this responder can work for multiple cars...The owners manual tells you how to check.
Posted on Feb 18, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Python same as Viper?
Hello Anthony,
This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
Feb 03, 2014 | Directed Electronics 479V Remote Gen 2...
When I try and arm my viper system it tells me it armed and then the arm and function LEDs flash. Help
That's what its supposed to do on the 2way remote. You would have recieved a 2 way and a 1way remote. The 2 way will chirp when it recieves a signal, whereas the 1way will not.
On the back of both remotes it will notate 2way or 1way.
cheers!!
Sep 26, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have misplaced my remote control key after returning from work. How can I find it please?
If you know its at home or near there. Lock/arm the security system from the 1way remote and then set the alarm off either by opening door with the KEY or hitting the car to set off the shock sensor. The 2way remote will start making lots of noise AS THE ALARM IS GOING OFF.
Now if you lost the 1way remote, there is really no easy solution except your eyes.
cheers!!
Sep 04, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I recently installed a python 872 on my 2002 maxima. Now everytime i use the remote start and open the trunk the car shuts off and restarts in about 10 seconds. I had other dei alarms and never had that...
It's possible that the installer has the engine monitoring option programmed for voltage and, the unit sees a drop in voltage when operating the trunk...causing the remote starter to shut down. If so, try programming the unit for tachless instead or, hook up the tach wire.
Jun 10, 2011 | 872 Responder LE Security Remote Start
Is the 592 safe for manual transmissions?
Yes, the 592 is actually designed for a manual transmission remote starter installation. Your only concern should be the installation of said component. If the unit is installed properly, there should be no problem with the unit or your vehicle.
Apr 13, 2011 | 592 Responder HD Color SuperCode SST 2Way...
Hi, my old remote key pad used to lock itself so if I bumped it in my pocket it wouldnt start. I bought a new 2 way recently but the key pad stays unlocked. How do I get it lock?
Press and hold the "f" for 8 seconds to access the remote programming features. The remote will emit one long beep and the LEDs will illuminate. Press the unlock button to access the remote programming features. Two transmit LEDs will flashes and two beeps indicate the remote programming features are accessed. Press the lock button on the remote( LED on indicates auto locking on, LED off indicates auto locking off). Press and release "f" button to exit programming.
Apr 12, 2011 | 872 Responder LE keyless entry security...
My system is on a silent mode or something, it still engages and dis-engages, and locks and unlocks, just that when I press the transmitter, it doesn't beep and horn doens't beep.
take the battery out for a few minutes then replace it, or if you have many custom settings, you have to press and hold the side button until options pop up.
IM GONNA BE HONEST, I HAVE NOT USED THIS DEVICE, BUT I HAVE A PRESTIGE ALARM WHICH IS MUCH THE SAME.
Hold the buttons in combinations. by themselves and so on until you get a menu, then press a button to change the value or the option, this is the best way to get to know your 2way responder....
GOOD LUCK AND PLS RATE THIS POST FIXYA!!!!!
Jun 03, 2010 | Install Essentials 489P Responder 2-way...
872 Responder LE Security Remote Start Logo
529 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
