Question about Alpine CDM-7861 CD Player
CDM 7859RB Detachable faceplate won't light up. I took the unit out and applied 12V to power and accessory inputs. Voltage appeared on inputs to faceplate but no signs of life.
Try replacing the display lamp. Part # 65T2531Y01 LAMP LOC# SFL1 at about $12. At pacificcoastparts.com Easy to install after unsoldering lcd display. Don't be intimidated, it's easy. Good luck
Posted on Aug 27, 2007
    Genius:
  • 1,074 Answers
Clean the contacts of the connections if that does not work it is time to call a tech or replace the face plate could be faulty.good luck.
Posted on Apr 28, 2007
SOURCE:
I have a Sony CDX-GT310 FM/AM Compact Disc Player with detachable faceplate. The unit still plays fine, but the display on the faceplate quit working. I've tried resetting the unit as well as cutting...
check the connectors between the faceplate and the unit carfully they can get damaged with constant removing/refitting if not the faceplate and/or unit is faulty
Dec 09, 2017 | Sony CDX-GT310 CD Player
Installed unit, there is obvious power, but the display does not light. Will accept and eject cd, but will not play.
At times a radio can have voltage at the yellow (12v memory wire) and no voltage at the red (12v ignition wire) which turns the radio on and off. If this is the case you may have a blown fuse or if it is a data based system the factory radio turns on with data and not voltage. If you have a data system in your vehicle there will be no 12 ignition wire present. You will then have to use a data/can-bus interface (recommended) or run a wire to and ignition source (this method does not retain any factory data features or safety chimes)
Jun 07, 2010 | Kenwood KDC-MP342U Car CD Player
My Alpine CDE 7872 faceplate goes blank intermittently, the unit still functions, just can't see what station you are on, what track, volume, etc...
is the faceplate detachable? if so remove it and clean the metal contacts on both the din unit itself and the faceplate with rubbing alcohol on a cotton swab or Q tip.
if it is not a detachable face, then i would say an internal solder joint is starting to come loose, that is an older alpine model number after all.
Dec 16, 2009 | Alpine CDE-7872 CD Player
My display stays on for about 3 seconds then it turns off until
If this model has a detachable faceplate,
Remove the faceplate and clean down the contacts with metho and a cotton bud.
Over time usually corrosion and dirt etc builds up on these terminals making them loose cotact when you touch the faceplate.
This is the most commonly known problem alpine units.
Other common problems is the power supply failing /amplifier.
Hope this helps you out
Cheers
Steve
Apr 02, 2009 | Alpine CDA-9805 CD Player
Sony XR-C2600 car stereo stuck in demo mode
Sony XR C2600
  • Press release button on faceplate.
  • Remove the faceplate.
  • Clean the contacts in system and faceplate with alcohol.
  • Voila, all button works now
Bullet Sankar India
Feb 05, 2009 | Car Audio & Video
Kenwood KDC-X717 - Facplate opens when powered on, stays open. No display.
I've had this problem before. The ribbon cable needs to be replaced. They wear out every few years. Take it in for service. Or do you want to sell it? I need the face plate for mine.
Nov 06, 2008 | Kenwood KDC-X717 CD Player
Installing CDM-7836 into a Boat
Yes I can help, the blue/white wire isn't meant for that purpose. That wire is meant for an amplifier turn-on. the wire you want to use is the red that is the accessory lead. What I would recommend is finding a constant 12V to hook to the Yellow and hook the switch 12V to the red. This way your radio will retain memory. Or you can connect both the red and yellow to that switch and never turn the switch off. Simply use the on/off button on the radio. Good Luck I hope I could help.
-Andrew Hawkins
Jun 18, 2008 | Alpine CDM-7834
Alpine CDM-7833
what wirers are for power
Jan 13, 2008 | Alpine CDM-7833
Alpine CDM-7861 CD Player Logo
254 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
