304w hp wont load
I have a 304w hp i turn it on and nothing on montior black screen , i can see and feel cpu fans on and feel the hard drive its running , but nothing the led light on back stays green and no beeps,
  • Jamie
    Jamie Dec 30, 2008
    ok i did that and nothing happened and some alrams went off , then i seen where i left something undone so i fixed that, and restarted and no aalrams now but still no load ...
  • Jamie
    Jamie Dec 31, 2008
    ok i did that as well and when i took the hard drive out , and turned it on , the screen was still blank, so i changed memory sticks one that i knew was good, and still the same promblem.. i really am thankful for your helping me !!!
    Problem Solver:
  • 18 Answers
First try removing the hard drive,and turn on the power. If the screen is till blank then either the memory sticks are no good,or the power supply to the screen could be tripping. But if the screen is not blank then your "MBR" (media boot record) is missing or off track.
Posted on Dec 31, 2008
    Novelist:
  • 146 Answers
Try pulling the plug from the back of the machine or the wall and then plug it back in and see if it will come up. It may be stuck in what I call a voltage loop. You can also try re-seating the card and memory and making sure the cable from the monitor is connected firmly.
If it doesn't do anything it is possible that either the video card is going bad, the power supply is failing, memory is bad or possibly the motherboard is shot.
Let me know if I can help any further.
Cheers
Posted on Dec 29, 2008
  • Shayne Schecht Dec 31, 2008
    Sounds like either the video card is bad or possibly the motherboard. I have see bad power supplies cause that too. Start with a video card and go from there.
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
HP media center pc ,1170n will not boot. black screen. You can hear the fan come on but black screen.
Sounds like a capacitor has blown on the motherboard, but before condemning it, check the following:
1.) Does the CPU fan turn and does the heatsink get warm after a few minutes?
(This indicates that power is at least getting to the CPU
2.) Check connections of ALL the main power connectors (ie: the 20/24 pin plug to the mainboard and the smaller 4 pin plug to the mainboard.
(If not firmly inserted will stop the board from firing up)
3.) Check the graphics card is firmly seated and test with anew graphics card to eliminate the issue being with the graphics card / check tightness of the VGA cable to monitor and card
4.) Remove all but the main power and 4 pin power plugs and try rebooting to eliminate hard drive or DVD drive failure
5.) Remove and replace each ram module in turn try booting in between
6.) If you have a spare PSU, replace the existing one and test the board using that, sometimes the PSU appears to work, but lacks power to fire up the board.
After all that, you are down to the mobo or CPU, you can try a new CPU, but I feel that the issue is with a blown capacitor or a burned circuit trace, only close inspection of the mobo will reveal bulging, leaking or blown capacitiors (small cylinder like things on the motherboard)
Jan 17, 2011 | Computers & Internet
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
HP ZE2000 blank screen on start up.
you need to change the lcd inverter card of your note book
Oct 21, 2009 | HP Pavilion ze2000 Notebook
My computer won't start.
check if the hard drive led is on so its the vid card if not its your motherboard because the fans are still running and its mean that the cpu is working but no activity
Jul 05, 2009 | Computers & Internet
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
Wont load up home screen.
Hello. Try a different hard drive. I have only seen a couple machines do this, but replacing the hard drive fixed it both times. Thanks!
Jan 17, 2009 | Sony Playstation 3 (PS3) Console
On powering on'the screen remains black and the ethernet plug is flickering. no sound from the hard drive
the hard drive could have failed..Try a hard start to see if it will react. Do you get any beeps?? a warning beep or beeps may indicate a hard drive failure. Try to get into C-Mode set up. click alt/cntrl/del as you turn on the set.or alt/cntrl F10. Hard drive failures can happen if ther is to much written to the drive or just a plain 'Crash'.
Oct 14, 2008 | HP Computers & Internet
Computer
Check that the hard drive connectors have not become loose on the board or the drive. Also check you havent lost a little black jumper off the back of the drive.
Oct 26, 2007 | Compaq Presario sr1111nx 2.53GHz Celeron...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
