Question about Canon PowerShot A530 Digital Camera
Computer not finding camera
I seem to be having a problem with my digital camera not communicating with the computer. I've checked the USB cords, and plugged other devices in to ensure it is not the cable. I have uninstalled & reinstalled the program twice. Any suggestions? COuld this be an internal problem within the camera?
    Problem Solver:
  • 40 Answers
Most cameras need to be turned on. Also, some cameras have a little switch or button to push in order to transfer images to 'puter. Actually, you probably don't even need to install whatever program you did. Unless perhaps you're running windows 98 & computer needs the drivers. So, next time you try to transfer images, click on "my computer" and you should see your camera. If not, that's weird. In which case, simply buy or borrow a card reader & insert your card and hook it up to the computer. It should work for sure.
Posted on Apr 29, 2007
I have a Nikon Coolpix 7900 camera I purchased used. It came without the proper USB cord, so I purchased one separately. When I attached the camera to the USB port of my computer (and I've tried...
I'm afraid that USB port has been damaged and is drawing excessive current causing the error message. You are at least fortunate in that your computers' ports are protected since the camera could have otherwise caused damage. Using a basic multimeter one could probably measure across the pins 1 & 4 to determine if the camera's input is shorted; it should in no case measure less than 5-6 Ohms regardless of lead polarity. The current capability of a USB port varies by version but is between 500 & 900 Milliamperes.
Sep 23, 2011 | Nikon Coolpix 3200 Digital Camera
I have been using my G11 with no problems for a year. Just tried to download pix and keep getting "Communication error". Checked the cord, it's fine, turned camera off and on several times,...
hi kbailey. Turn on the camera and go to the menu. find the reset function. Reset the camera. This means you are returning it to all of the settings it was at when it was brand new out of the box. Joe
Thanks for choosing Fixya!
Nov 26, 2010 | Canon PowerShot G11 Digital Camera
When i plugg in my camera to the computer it wont chrge it wont even turn on if there is a soultion please contact me asap!!!
Hey Sophia,
Have you checked the battery, as the problem seems to be with battery
First of all checked if the battery is inserted properly
Take it off and re-insert it... make sure the +ve and -ve are set properly
If it still does not work...you got to replace the battery
Thanks
Oct 08, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
How do I charge my camera with a usb cord. It
You have to use the battery charger included with the camera, or a replacement unit. The camera does not have charging circuitry built-in. Connecting the camera to a computer runs down the battery faster, as the camera must then communicate with the computer.
Apr 06, 2010 | Olympus Stylus 1010 Digital Camera
My camera won't be recognized when it's hooked up...
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
May 17, 2009 | Olympus FE3010 Digital Camera
Olympus x-785 digital camera is not identified by my pc
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. Sounds like you may need to reinstall the device driver for the camera. The camera uses the driver usbstor.
May 06, 2009 | Olympus FE-120 Digital Camera
Fujifilm z10 Will Not Connect to Computer
Your computer might need the driver for that particular camera reinstalled. You should be able to go to Fuji's website and download an updated driver for your camera make and model. Also, just to be sure, most cameras have to be turned to the ON position when you download data. My Kodak will not communicate with my P.C. unless I have it ON when I attach the U.S.B. cord - a couple of times I have sat there waiting and nothing, until I realize I did not have it ON. Also you may want to make sure your U.S.B cord is O.K. - replacements are inexpensive. Good Luck!!!
Nov 07, 2008 | Fuji FinePix Z10fd Digital Camera
Communication error when uploading pictures on computer
I had the same problem. My problem was that there were more than 1,000 images stored on the memory card. Once I deleted some of the images from the camera memory card, I was able to download pictures again.
Aug 10, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Olympus E510
Make sure the camera is on and STORAGE is selected on the camera screen when connected to the computer. You will need to have STORAGE highlighted and select OK on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Aug 01, 2008 | Olympus Cameras
Connecting to computer.
Try using a different computer and if it doesnt work get a new usb cord.
Jul 28, 2008 | Samsung Digimax D53 Digital Camera
Canon PowerShot A530 Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
