CANON i-SENSYS MF8180C
I have the above all in one canon printer which now shows Error message on the screen ''E071'' ?? its not allowing me to print or do any functioning unless i fix the above problem?
Can yu help me to sort out this issue,
Thanks and regards
sri
  • 76 Answers
Hi happy new year
E071 ITB home position sensor fault Check the connector of the ITB home position sensor.
Replace the ITB home position sensor.
Replace the DC controller PCB.
Posted on Dec 29, 2008
Canon isensys MF8180C show System Error E100 while printing operation.
This error means: there is a problem with the laser unit. Dirty or faulty
Jun 20, 2015 | Canon imageCLASS MF8180C All-In-One Laser...
Error code 301-0001 on i-sensys MF 4450
Show error code 301-0001 after press (Problem with Canon i-SENSYS MF4140 All-In-One Laser Printer
Error code 301-0001 on i-sensys MF 4450cont: 8016185745-dulal
Nov 27, 2012 | Canon i-SENSYS MF4140 All-In-One Laser...
Canon i-sensys mf 4010 showing system error E225 on screen
canon i-sensys mf 4010 showing system error E225 on screen
Jan 02, 2011 | Canon i-SENSYS MF4140 All-In-One Laser...
SYSTEM ERROR E000 on Canon I-SENSYS MF 4690PL. Please help me!!! Thank you all!!!
Hi flord, this error code on CANON, (E000) means that the Fusing unit not heating up, the mostly of cases this unit is damaged and need to be replaced.
you migth contact canon support to replace the fuser of the printer. maybe you have printer too many sheets.
Apr 07, 2010 | Canon i-SENSYS MF4660PL - 1827B021AA - -...
How to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in lucksmile.gif
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that errorsmile.gif let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
Apr 28, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon color imageclass mf8180c, Iam getting '' SYSTEM ERROR E071
I had the same error message E071. Had to call out an engineer who diagnose the Drum 701 was leaking toner - this got on the electrical contacts at the bottom of the drum. He cleaned the contacts on the drum and in the machine - put my old Drum in there and all is OK. The drum was 9 months old and not had much use so I am trying to get a replacement from Canon under warantee.
Apr 06, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon ImageClass MF 8180c Error Code E071
i had the same problem, had to replace the drum unit
Mar 10, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon MF8180c
E071 error stands for ITB position sensor fault,so you may try to check if the ITB belt is ok, if there is no paper left overs or similar, but this error can occure when the main board ( dc controller ) is defective.
Nov 01, 2008 | Canon imageRUNNER C3200 Color Printer
I have a system error e071 on mf8180c image class.
Hi, as per the manual it says
Solution
Jul 25, 2008 | Office Equipment & Supplies
172 people viewed this question
k24674
jasbo
jasbo
