Question about Tomtom ONE GPS Receiver
Tomtom One won't turn on.
The TomTom will no t turn on, even though the green light is on. I have tried different connections, different power sources and connecting it to the computer but the screen stays blank. It has worked fine until now.
  • 3 more comments
  • Anonymous Dec 29, 2008
    Attempted to turn it on but get nothing. Left it on charge for an hour with same results.
  • dalebr_wn Jan 03, 2009
    had my tomtom one for many months and no problems. Till now. Have pushed the button down sufficient time.
  • figlets2002 Jan 03, 2009
    will not turn on tried reset button still nothing
  • wthor_88 Jan 05, 2009
    I have a TOMTOM One, it worked good for a couple months. Now I can't get it to come on, the green light is on for power. I lost my directions and was also wandering if the internal battery is able to be replaced?
    What else could it be
  • psycho138 Jan 06, 2009
    I have the same problem, but if you can ever get it to come on, you need to reset your factory settings. It is a pain, and you lose everything, but it will work fine for a while after you do this.
Hold down the on button for 2 sec.Gerry
Posted on Jan 03, 2009
  • bangquackado Sep 24, 2011
    So what is the answer to this?
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
TOMTOM GO LIVE 1000 Orange charge light will not
The battery is stuffed and needs replacing. It is a well know issue.
Aug 28, 2013 | Tomtom One Europe v2 GPS Receiver
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
TomTom GO 910 won't turn on.
Two possibilities:
- if someone has used the wrong charger, and connected it to a 12V supply, the mainboard may be damaged. In that case, you need a replacement.
- the battery may be discharged. Even if the green light is on, it doesn't necessarily charge up. Try pushing it hard onto the mount for a few minutes, then see if it will turn on.
Feb 08, 2010 | Tomtom GO 910
How do I reset my TOMTOM N14644?
Go to TOM TOM´s homepage http://www.tomtom.com/services/
Connect the GPS unit to the PC using the USB2 connection.
You will be given the possibility to restore the unit´s files. This takes a while, but it solved the problem for me.
Nov 04, 2009 | Tomtom ONE GPS Receiver
Tomtom One 3rd Edition will show green light but will not turn on
If you have an SD card in then remove it and try to boot it up.
It is possible that the SD card is corrupt or faulty.
If it does not power up with no SD card then it may well need to go in for repair.
Should you get it to boot without the SD card then back it up straight away.
Reformat your card (preferably in a card reader) and then restore to the card . You should then be able to put the card back in
Aug 20, 2009 | GPS
Yesterday, when driving, I noticed that the device said i was receiving no signal, even though I was out on the interstate... I got frustrated and turned it off... I figured that it would give it ample...
The green light does not necessarily mean there is power to the unit or charging the battery. If the unit is more than 3-5 years old, you may have success with replacing the battery. If you have a power source with sufficient current output capabilities then you could try that with the battery removed.
Jun 16, 2009 | Tomtom GO 910 GPS Receiver
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
Dec 19, 2008 | Tomtom GO 720 GPS Receiver
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Tomtom ONE GPS Receiver Logo
153 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
