Question about Sony PlayStation Portable (PSP) Console
I forgot my psp on my hot temp. car
I forgot my psp on my car and the temp. becomes hot and the windows are closed,so my psp not working properly!!?? i need your help so pls>>>>>>ans. my questions!!!!!!
  • Somu Cool
    Somu Cool May 11, 2010
    r u a girl
    Problem Solver:
  • 13 Answers
Might work if you put in the frezzer for 5 min
Posted on Dec 30, 2008
I have an LG American fridge freezer GRB207TUJA which the edge where the doors close on is very very hot
This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | LG Refrigerators
Hi is it normal that the middle Paleo that the doors close onto seems really hot? We have an American style fridge freezer, everything else seems ok, but I have never noticed it before!! Thank you
Again a similar post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | Refrigerators
In 03 chev venture. Mini vanHeat takes long time to get hot
Do you know if the radiator is full of coolant ?
Does the gauge on the dash show the engine temp to be cold after you run the engine ?
Could be the thermostat is not closing.
If the heater hoses are getting hot, could be a blend door problem under the dash.
Jan 14, 2013 | Cars & Trucks
I was charging my psp go in stanby mode for a nite. sudenly it turn on by it self, and when i touch it. my psp become so hot. what wrong with my psp? it is manufacture defect? Thks
If your PSP is getting hot when charging it, please unplug it.
Yes there is a defect in the battery or the PSP itself.
It is possible for such a defect to get hot enough to melt and to start a fire.
Don't charge it anymore.
Mar 14, 2011 | Video Game Consoles & Games
Slim psp no display/sound but green light on
Turn On your psp ress the directional button. If there is sound from the menu. I think you lcd backlight dead or the hardware conecction not work properly that make the lcd backlight died
Sep 03, 2010 | Sony PlayStation Portable (PSP) Slim...
Why is engine temperature getting hot
Maybe the termostat is not working properly!
Jul 03, 2010 | 1999 Saab 9-5
Engine heats to proper temp, heater fan works, already replaced termostat. heater core doesn't seem to be leaking.
Find where both hoses are going to the heater core from the firewall side after engine is up to temp.Touch them with your hand.If they are both quite warm the water is flowing thru the heater core. If only one is hot the core is stopped up. If both are hot and still no heat the heater door in the heater box is staying closed.
Jan 15, 2010 | 2002 Ford Taurus
2001 pontiac aztec, temp guage shows (very) high) temp reading. I take the battery cable off, replace cable, then it appears normal. I have done this for 4 months, everything is OK. Now it no longer solves...
if you have high miles, 75k or more I would go ahead and have tempature sensor and thermostat it self change. I don't see battery cable would have any bearing to the temperature guage or cooling process. Both switch work almost the same, at time it work well other time it read or work incorrectly because it a sign of unit becoming faulty. If the temperature sensor is faulty half of the time it well give you incorrect reading however if the temp sensor working properly and the Thermostat is not, you will also get a high temp reading due to the Thermostat is not working properly allowing the hot antifreeze to flow out from the engine to the radiator which cause the hot antifreeze to be remain lock up in the engine block. Thermostat suppose to open and close when it reach its temperature; at the same time I would also replace thermostat switch which operate the cooling fan. all three tend to go bad over times; replacing all three is a great ideas. Thermostat, thermostat switch and temperature sensor.
Oct 21, 2009 | 2001 Pontiac Aztek
The heater is only blowing cold air
First, check to make sure you are not low on coolant. Check hoses going to heater and see if they are getting hot.(one should be hot, the other should be slightly less hot but not cold or just warm) Check heater control valve to make sure that it is operating, Check that plenum door is opening properly inside the cabin, in the heater box. If you have done any work at all on cooling system, run the engine 'till it reaches operating temp with radiator cap off...sometimes htr core can become air-bound. Also...goes without saying, but make sure that engine reaches normal operating temp while driving. If not check thermostat!
Jan 24, 2009 | 2004 Jeep Grand Cherokee
Sony PlayStation Portable (PSP) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
