Cannot connect to a mobile network,call setting is disable no network signal
There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet. you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings . (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection
click start Control Panel - Network Connections - right click on 'Wireless connection'
this will vary depending on your operating system
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
enabled
hope this helps
