No boot or beeps
My pc just recently started having some problems. I turn it on, and the fans would come on and also all the components (hard drive, video card etc.) would power up. However I would recieve no beeps or video to my monitor. I have tried every thing I can do with the resources I have, save for buying a brand new mother board. I have replaced the CMOS battery, reset the bios, disasembled my computer, and cleaned off every thing. My final analasyse is that my mother board is just dead and needs replaced. However I get the feeling that thier is somthing that I am not trying. My mother board is an ASUS P4P8X. Any help would be greatly apreaciated
  • jamescW Apr 14, 2009
    The same thing started happening with my Medion last night. No boot/beeps. The fan just blows continuously. Did you ever determine the problem?
  • 177 Answers
My dad had the same problem but it was The Power Circuit needed replacing as the power board had burnt out.
Posted on Dec 29, 2008
    Genius:
  • 1,913 Answers
Clea your processor and then refix it.then alsom check with other ram may be your ram is faulty.also some times earthing problem creates problem in booting proces.
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    Oct 09, 2011 | HP Mini 1000 Netbook
    Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
    Instructions
    1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
      Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
    2. The BIOS queries various hardware components used for the startup boot process.
      Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
      Or
      The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
      Or
      A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
      If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
    3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
      Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
      The boot check has detected a communication error or conflict with a hardware component that must be corrected.
    4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
      Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
      The boot check has detected a hardware driver error or a software conflict that must be corrected.
    5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
      The Windows logo displays during this step.
      Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
      An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
      Or
      A black screen appears and the computer attempts to restart.
      The Windows self-check has detected a software conflict that must be corrected.
    Jan 09, 2011 | Gateway GT4016 Desktop PC
    MY T6524, will not start I press the button and the hard drive light goes red then nothing comes on the monitor
    Disconnect all devices from the power supply EXCEPT the motherboard
    Remove any extra cards including video etc.(plug monitor into the onboard)
    If you hear any beeps these can indictate where the fault is.
    either of these sites below will help you further with that
    Beep codes Pc
    More beep codes
    Power up the pc and see if the fans are working.
    If not then double check the power connections to the board.
    If you still have no fans it is time to suspect the power supply as the probable cause.
    If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
    Now connect one drive only and boot again.
    Repeat that until you identify the component that is giving you a problem.
    Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
    If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
    Nov 19, 2009 | E-Machines T6524 PC Desktop
    My pc turns on but wont boot up was fine one day would not work the next?
    Does it show the hard drive in the bio's? If so and you have the operating disk,,, load the drivers from the disk and when prompted, use the repair mode provided therein to check disk (CHKDSK) It will scan and repair any defects that may be causing the program to not load.
    Oct 10, 2009 | Computers & Internet
    E-machine wont boot up. It has power,feels like
    Beep codes Pc
    More beep codes
    Sep 28, 2009 | E-Machines eMachines Desktop PC
    I get the BIOS screen and then it turns to a blank screen with a blinking cursor in the upper left corner. Even if I try to go to setup or boot menu it will do the same thing. Over the last couple days I...
    Sometimes this indicates that there is a problem with your hd or other components, Try booting off your winodws cd/dvd and go to the repair console and enter "fixmbr" See if that helps. If it is an older version of windows (311, 98, 95) try running fdisk from boot disk and make sure the partition is active.
    Hope this helps
    Sep 25, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
    Have a Dell Dimension 3000. It will not turn on. The power supply is good. How do I tell if I need to replace the mother board or the processer?
    The best way forward in these instances is to strip the machine down to basics. Remove all boards and extra drives and just leave the motherboard with one graphics card. Then try rebooting again. If it boots, then start replacing the peripherals and cards one at at time. Eventually you will work out what the problem is!
    If it still does not boot, try swapping the memory cards ... or if you only have one then try reseating it. SIMMS/DIMMS can work loose with the vibrations of hard drives/fans etc.
    Sep 24, 2009 | Dell Dimension 3000 PC Desktop
    HP Pavilion dv4 not turning on
    You must be facing any of these four issues:
    1) power issue
    2) No POST
    3) NO Boot
    4) No video
    Power issue - the system does not turn on at all. In this case check the AC adapter and the battery.
    No POST - You may have to check the Memory, Hard drive and the optical drive. Can also be an issue with the video card2.gif/ key board/ mouse/main board which can prevent the system from turning on.
    try reseating all the components above except the motherboard.
    No Boot - Issue with the Operating system. Try booting into safe mode and check whether the system turns on perfectly. If so try to uninstall all the software you do not use. and may also consider a system restore2.gif else consider a Dell Complete factory restore.
    No video - Try flashing light on the screen and look for the desktop. If you see the icons then probably the back light needs to be changed else the issue is with the display itself or the video card.
    Kindly comment with more details about the problem.
    Sep 23, 2009 | HP Pavilion dv4000 Notebook
    Computers & Internet Logo
    123 people viewed this question
    David Payne
    David Payne
