Question about Sony PlayStation 2 (PS2) Console
My playstation doenst work iam not able to close the door properly since it feel down
  • 38 Answers
This is a fat PS2 I assume. The drive tray has come off of it's track.
You will need to open up the PS2 and remove the inner cover of the DVD drive. With slow and even pressure you will need to twist the drive tray so that it pops back into place.
The tray is surprisingly flexible and you should have little trouble getting it back into place. I've done this several times with my own machines as well as others.
The number one obstacle that you will face is to not break off the wires to the power and eject buttons. When you remove the top half of the shell you should flip it toward the front of the machine then swing it around so that the wires will have slack.
Posted on Apr 03, 2009
sounds like latch is not allined properly ,try moving striker pin a little in or out up or down ,slowly closes door to see if you feel any indecators as to what is the problem., good luck.
Oct 01, 2012 | 1989 Honda Accord 4 Door
My Mercedes Benz 500 S L (1995) door latch seems to be creating a problem with my convertible top & power windows . A red light indicator switch is blinking red or a steady red. I have been given...
quick way to adjust door if its dropped is put a jack with a piece of wood on the top and open door ajar and then jack the door up a bit then jump up and down on the sill till you get it at the right height to close easy but this is not the roof problem iam sure but?-¿-? i could be wrong as i dont know everything
Aug 26, 2011 | Mercedes-Benz SL-Class Cars & Trucks
Microwave not heating up food
Please remove the cover and check the door safety interlock switch. Then failed, the oven doenst know the door is closed and will not turn on the heat.
Thanks for your visit today.
Jan 06, 2011 | GE XL1800 1100 Watts Microwave Oven
While playing games home button keeps popping up saying do you want to go to home menu. What is wrong,is it fixable?
just open our umd door or do not close it properly(tightly) while playing games...........the home button will not appear again unless you close the umd door.......hope it work for you...
Aug 20, 2010 | Sony PlayStation Portable (PSP) Console
The passenger side front door has a terrible draft noise when we are moving. We cannot feel a draft at all, but something is not right. The seal is obviously not working correctly. What should I look for...
Is the seal correctly fitted? Does the door rattle when it is closed properly? Does it look like it is not properly shut when it is closed and if you push it from the outside is there a bit of give? If so your slam plate needs to be loosened and pushed in a bit to hold the door tighter, not too much or the door won't close at all. Another thing you can look for it a badly fitting window frame. If there is too much space between the car body and the window frame wind will whistle arond the gap. To see if that is the culprit, seal it with duct tape and take it for a ride. If that is the problem, open the door.wind the window fully down, stand between the car and the open door and carefully pull the top of the window frame towards you. If you can movw it in by 1/2 inch it will make an effective seal when the door is closed. Go carefully though.
Apr 06, 2010 | 2006 Chevrolet Trailblazer
Westinghouse oven does not close fully.can door hinge be adjusted?
If it has a drop down door, the only solution is to replace both door hinges, if it is hinged on one side, then the door catch, or door striker could be worn, these are easily replaced,
Please rate my solution.
Oct 31, 2009 | Ovens
I can't open the rear door to my LR3, the other doors are fine.
hi i think i have the same problem when i unlock the rear door it makes the sound like the lock is openning but then it closes again, and it doesnt let me open the tailgate door. i have tried to hold the unlock and lock button for 3 seconds but it still doenst work would like to know if u have solved the problem and how ?
Jun 14, 2009 | 2005 Land Rover LR3
Remote control to garage door only works when iam one inch from u
I had a simaler problem, after installing a shelf to get rid of clutter and organize tools. I had traced it down to a Rigid cordless drill charger. The garage door opener signal was interfered with only when the battery pack was on the charger,my other drill charger have no affect on the garage door remote performance but when I charge that battery pack the range is cut down by 75 to 100 feet, it is amatter of finding out what is interfering with your signal. Same principal as using a jammer to disrupt police radar. I hope this helps
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Sony PlayStation 2 (PS2) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
