Question about HP 10bII Calculator
HP 10 BII is not calculating correctly.
HELP! I have a test in the morning and my calculator is messed up!!
It is not calculating correctly on some things and on others it is.
EX:
Correctly calculating:
-300 PMT
30*12 N
7 I
FV
but will not calculate:
30 N
10 I
-250 PMT
FV
it is all whacked out!
SOURCE: Does a scientific calculator have cash flow
no..................
Posted on Feb 21, 2010
  • 102366 Answers
SOURCE: My BAII isnt calculating correctly
Change the payments-per-year to 1 to get the correct answer. Press 2nd [P/Y] 1 ENTER.
To pay off a loan of $3245 at 12% annual interest, you can either make 6 monthly payments of $559.91 and pay it off in half a year or make 6 annual payments of $789.27 and pay it off in six years.
Posted on Nov 26, 2010
  • 102366 Answers
SOURCE: Calculating PV where n=5; i=6%; $18,400=pmt; 0=FV.
Check to make sure you have the proper value set for payments-per-year.
  • 38 Answers
SOURCE: Help please! How do I
Please refer to the link to formula involving loan calculation: http://www.docstoc.com/docs/64563308/Calculating-Loan-Payments-Using-Reducing-Balance-Formula
Posted on Mar 21, 2011
  • 37 Answers
SOURCE: Calculator calculated (solving for FV) 5 N, 10
This is happening because your calculator is converting the 10% interest figure into a monthly amount (ie 0.833333%), but it isn't changing the number of periods or the periodic payment into monthly equivalents. In both cases, it is assuming that payments are made at the end of each period.
So the figure of 10,168.06 is arrived at as follows:
end of period 1: 2,000.00
end of period 2: 2,000 x 1.00833333 + 2,000 = 4,016.67
end of period 3: 4,016.67 x 1.00833333 + 2,000 = 6,050.14
end of period 4: 6,050.14 x 1.00833333 + 2,000 = 8,100.56
end of period 5: 8,100.56 x 1.00833333 + 2,000 = 10,168.06
whereas the figure of 12,210.20 is arrived at as follows:
end of period 2: 2,000 x 1.1 + 2,000 = 4,200.00
end of period 3: 4,200 x 1.1 + 2,000 = 6,620.00
end of period 4: 6,620 x 1.1 + 2,000 = 9,282.00
end of period 5: 9,282 x 1.1 + 2,000 = 12,210.20
You will need to find out from your user manual how to stop this from happening, so that all the numbers remain as annual figures. It will involve setting the number of payments per year [P/YR] to 1 instead of 12.
Posted on Oct 06, 2011
Scientific notation on BD - 107i calculator?
Of course it is possible!
There seem to be many ways to do this on this calculator.
Assuming we cannot do scientific notation, we can always do
6.02 x 10 ^ 23 / 3.01 x 10 ^23. However, we have to put brackets in to get BEDMAS to work correctly!
6.02 x 10^23 / (3.01 x 10^23) - for the 10^23, type 10 then the y to the x key and then 23.
Using the scientific notation, we can type in 6.02 EXP 23 / 3.01 EXP 23.
Good luck with your chemistry test tomorrow!
Take care,
Paul
Nov 28, 2016 | Office Equipment & Supplies
My calculator, hp32sII messed up with the display. how do I reset it?
To reset the HP model 32S II calculator, hold down the [C] key and press the [LN] key. It may be necessary to repeat these keystrokes.
Feb 24, 2015 | HP 32sII Calculator
Binary operation in hp 10 s
I am sorry to say but the calculator does not handle Base-N calculations. It only has three calculation types :General (basic) COMPutations, Standard deviation calculation, and regressions.
Mar 31, 2012 | HP 10s Scientific Calculator
Okay, so I'm trying to fix my exponents over here. I needed to find out what 0.77 is to the 22nd Power...so i put it in my calculator and get this CRAZY number: 3.18270183 x 10^03...What the hell???? How...
Your calculator is giving you the correct answer, telling you that 0.77 to the 22nd is about 3.1827 times ten to the minus 3, or 0.0031827 . By default, the calculator will switch to scientific notation if the magnitude of the number is less than 10 to the minus 2, or 0.01. You can put the switch at 10 to the minus 9 by repeatedly pressing the MODE key until you reach the screen showing "Fix Sci Norm" on the top line. Press 3 to select Norm, then press 2 to select Norm2.
The calculator can only show ten digits. The only way it can show a number with ten or more leading zeroes is to switch to scientific notation.
Dec 06, 2010 | Casio FX-300MS Calculator
I am getting the wrong results when performing some basic FV math problems. Doy you have any math problems that would help test my calculator?
It might be more efficient to make the calculator perform a self-test. Here is the procedure.
Verifying Proper Operation (Self-Tests)
If it appears that the calculator will not turn on or otherwise is not operating properly, use one of the following procedures.
1. With the calculator off, hold down the [ON] key and press [X] (the multiply key)..
2. Release the [ON] key, then release the [X] key. This initiates a complete test of the calculator’s electronic circuitry. If everything is working correctly, within about 25 seconds (during which the word RUNNING the display should show –8,8,8,8,8,8,8,8,8,8, and all of the status indicators (except the * battery power indicator) should turn on. If the display shows Error 9, goes blank, or otherwise does not show the proper result, the calculator requires service.
Tests of the calculator’s electronics are also performed if the [+] key or the [divide] key is held down when [ON] is released. These tests are included in the calculator to be used in verifying that it is operating properly during manufacturing and service.
If you had suspected that the calculator was not working properly but the proper display was obtained in step 2, it is likely that you made an error in operating the calculator. We suggest you reread the section in this handbook applicable to your calculation — including, if appropriate, appendix A.
If it needs repairs, contact FixThatcal.org
Here are some examples from the manual (there is overlapping in the first two screen captures)
Mar 07, 2010 | HP 12c Calculator
The calculator is not showing any display after replacing the battery of HP 12C
Try verifying Proper Operation (Self-Tests)
Feb 21, 2010 | HP 12c Calculator
My 12c fin calculator will not come on even with a new battery.. help
you should perform calculator tests to verify the good working order of the calculator.
  1. With calculator OFF, press and HOLD the [X] key, then press [ON]
  2. Release the [ON] key, then the [X] key.
This sequence initiates a complete testing of the circuits. If all is well., the calculator should display -8,8,8,8,8,8,8,8,8,8 and all indicators should be lit for about 15s. The calculator displays running.
If calculator displays Error 9, another result, or displays nothing it needs to be repaired.
Hope it helps.
Thank you for using FixYa.
Nov 21, 2009 | HP 12c Calculator
BATTERY
Here is the a clippings for the info on your battery.
If you you want a the copy of the user manual, just let me know.
Enjoy
Aug 08, 2009 | HP 19BII Calculator
When i try expand solve or factor i get a dimension error
Using solve and factor requires correct mode and proper equation set up. Ref to manual might help.
Jul 20, 2009 | Texas Instruments TI-89 Calculator
HP 12c cALCULATOR
It is not calculating because your decimal point and the digit separator (that's the comma which automatically displays for every group of 3 digits) got messed up. To clear, turn the calculator OFF, then press and hold down the dot (that is the decimal point symbol) key while you press the ON key..
t
Sep 04, 2008 | HP 12c Calculator
HP 10bII Calculator Logo
224 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
