Question about Samsung (SC-152) Internal 52x CD-ROM Drive
CD-ROM icon appears when I click it it says 'Please enter a disk
Sir,My CD-ROM was connected to the CPU correctly.But when I insert a disk into it it loads but there was no display of 'Autoplay' option.When I move to my computer I clicked the one&only G folder named Removable Disk(G:)but it says Please insert a disk in G:.I have removed 2viruses presented in my computer but still this problem occurs.Give me some tips how to solve this problem
Arno
SOURCE: Samsung YP-T5 MP3 Player I/O error
I had the same problem and solved it with this: On the Samsung support page, thereĀ“s a knowledge base called "YP-T6 Or YP-MT6 Show No File And Zero Free Memory" you need to download the latest firmare from the downloads section, then with the uptader on the PC, remove the battery from the YP-T5 or 6 and connect the USB cable to a PC while pressing and holding the play button on the YP-T. It should connect in a recovery mode which allows you to update the firmware, format the flash drive and get going again !
Posted on Feb 24, 2007
sandrew
  • 2961 Answers
SOURCE: Combo drive CD not reading, but DVD ok
it may have dual laser and one that reads cd's is faulty, but try uninstalling the dvd drive first then re installing it to see if it cures it, if not the drive will need replacing. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers
Posted on Mar 30, 2007
smeago1
  • 136 Answers
SOURCE: CD-ROM icon missing on screen
Hedge,
Can you see it in your device manager? if you can't then its a physical problem which means you will need to double check your physical connections between the cdrom and your motherboard as well as the power connections.
Another way to double check is go to your bios and see if the biois detects your cdrom. If it doesnt then i think you cdrom is dead.
smeags.
Posted on Jan 07, 2008
  • 230 Answers
SOURCE: Connecting with PC
Make sure that the driver letter is not being "shared" with another letter. You might want to check in that "removable device " under "Manage".
Posted on May 05, 2008
mewms_14904
  • 1027 Answers
SOURCE: samsung sh-s182 not read cd and dvd
To check, go into the control panel, systems, hardware, device manager and uninstall the dvdrw, then reboot the machine and let windows install the device driver.
Posted on May 09, 2008
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
I am inserting the bootable cd in lg combo but every cd run but bootable cd not run please tell me how can adjust the bios settings
first check the CD you are using is boot able in other system if not write a bootable CD and insert the other thing is of the drive if the drive is old and the lens are weak the boot able cd wont work you will have to find anew drive to test that remove all the ide connectors or sata connectors from the motherboard except the CD drive insert the boot able cd and and restart the system then press del and enter bios setup and click advanced option and make sure the first boot drive is CD then save and exit in some motherboard you need to use f12 to select the boot device then click it and select the boot drive as cd ROM then click click it then you will see after post bios boot from cd ROM press enter it will ask for confirmation press enter again you system then boot from the cd now switch off the computer connect the hard disk and try again
Oct 16, 2011 | Computers & Internet
When you click on computer it doesnt even show the icon for the dvd/cd player. I can insert a disk, and here it run; but nothing happens. I try to locate the program in the all programs file but it is like...
check the dvd/cd Rom connection inside cpu, if it does not work then
right click on my computer icon and select Manage->Device Manager->DVD/CD ROM drive
and the right click on that and select enable
it may help you
Jul 24, 2011 | Acer Computers & Internet
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
Sir cricket 2007 is not running. i've installed it but when i click on icn to play, it shows message "please insert correct cd-rom,select ok and restart application"
First download and install daemon lite tool in your pc : second right click as shown in picture on game image file and bring cursor on open with and select daemon lite tool now come on desktop start the game through the shortcut on desktop the best way for playing game which ask for cd rom
May 21, 2011 | EA Sports Cricket 07 for Windows
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
Trouble installing my Samsung SCX-4200 printer
Good day Sir, That is common macintosh problem. There is described "driver not installed" at product List Window after you click Add and select USB. I suggest Reintall the software and make sure that you are using a high-quality cable.
Installing software Samsung scx-4200 for Macintosh
Verify the following before you install the software.
Operating System - Mac OS 10.3x or higher
RAM - 128 MB
Free Disk Space - 200MB
  1. Make sure that you connect your printer to the computer. Turn on your computer and printer.
  2. Insert the CD-ROM which came with your printer into the CD-ROM drive.
  3. Double-click CD-ROM icon that appears on your Macintosh desktop.
  4. Double-click the Mac_Installer folder.
  5. Double-click the Mac_printer folder.
  6. Double-click the Samsung SPL2 Installer icon.
  7. Enter the password and click OK.
  8. The Samsung SPL Installer window opens. Click Continue and then click Continue.
  9. Select Easy Install and click Install.
  10. After the installation is finished, click Quit.
Have a nice Day.
Dec 24, 2009 | Samsung SCX 4200 All-In-One Laser Printer
CD ROM DOES NOT APPEARS ON MY DESKTOP. WHEN I OPENS MY COMPUTER THERE`S DOES NOT APPEARS THE CD-ROM`S ICON.
1.check your connections of CD Rom inside the Cpu box, if any loose contacts there, then your cd rom wont appears on the computer,
2. change the data cable
3. connect different power socket to the cd rom
4. goto Bios setup, press Del key or F2 key to enter the Bios setup
5. check your cd to detect
6. save it and restart your computer
Jun 22, 2009 | Intel D101GGC Motherboard
PLEASE INSERT CORRECT CD-ROM CLICK OK AND RESTART APPLICA
insert the cricket cd right click and open he cd there wil be a folder named crack open that folder and copy the cricket icon
now right click on ur desktop cricket 2007 icon and go to properties click on find target the window that opens up paste the copied icon in the window if it ask to replace click on ok
Jun 21, 2009 | EA Sports Cricket 07 for Windows
"NTLDR" is missing"
Change your computer's boot sequence. Make sure that your computer's first boot sequence is the CD-ROM Drive.
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.Enter in the following commands
COPY X:i386NTLDR C:
COPY X:i386NTDETECT.COM C:
[where X=CD ROM Drive]
Take out the CD ROM and type exit
Jun 13, 2009 | Asrock 775i65GV Motherboard
Samsung (SC-152) Internal 52x CD-ROM Drive Logo
122 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
