Question about Canon Elura 60 Mini DV Digital Camcorder
DV In Message Won't let me output from DV
Hi, My Elura 60 won't transfer video through firewire to a computer or DVR. When I plug in the cable, the bottom right of the screen say's "DV IN" and to video comes through the connection. I've done this type of transfer a million times and I can't figure out what is wrong. I have made sure that the AV-DV OUT is turned off. Heck, I've actually tried it both ways. I've tried turning the camera on and off, plugging the DV cable in at different times. Please help, Chuck Temple chuckyte@gmail.com
  • 76 Answers
You will have to use process of elimination.first of all if dvd in on camera can you copy a video file from computer to camera??.if you can this rules out a faulty lead.if you dissconect the firewire at the camera side are there any bent pins on the socket of the camera??have seen the socket get damaged loads of times!.its dv out you should be looking for why turn it off.?try these and if still in trouble get advise or est from repair center
Posted on May 13, 2007
SOURCE:
SONY DSR PD 170 OR 170P IS THE CAMERA MODEL AND LAPTOP IS SONY VAIO VPCEG18FG. The camera has a DV firewire port and lap top has only 3 usb ports. I tried connecting it with a cable that ha s firewire...
This Camcorder does not support USB streaming with the Windows 7 Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.The Firewire to USB cable won't work with your camcorder,you will always end up with this error.
Click the link below for the instruction to transfer the video to the Computer using i.LINK cable.
>> http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
You Sony vaio laptop doesn't have firewire ports ,in this case you will need to purchase and install an firewire card ..>>
see link >>
http://www.ramelectronics.net/computer-parts/computer-accessories/firewire-i-link/firewire-cards/29972/prod29972.html
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Please let me know if you need further assistance on this issue .
Nov 13, 2011 | Video Cameras
What do I need to record videos from my camcorder to my computer.
A firewire cable is the only way.
USB can only download stills.
Apr 15, 2011 | Canon Elura 60 Mini DV Digital Camcorder
Why cant i just use a usb cable to put my videos on a computer instead of the DV cable that didnt come with thecamcorder
Simply because it won't wrok.
USB will only transfer stills from a cardn not video from the tape.
Use an appropriate firewire cable, also called iLink or IEEE1394.
Apr 09, 2011 | Canon ZR600 Mini DV Digital Camcorder
I am using an old, borrowed Canon NTSC Elura 100 camcorder with a Mini DV 60 tape. I do not have the original Picture Package software or the manual, and I am trying to transfer onto my computer, which...
You can download the manual, software, and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/elura_100
Dec 12, 2010 | Canon Elura 100 Mini DV Digital Camcorder
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
We are trying to get some Hi8 footage onto our macintosh computer. We have both the VHS camera and the Elura 90. We have a firewire and have successfully transfered lots of digital video onto the computer,...
the procedure is the same ..for vhs...but you will need a firewire cable ..also ..and a program that will import from device...The issue is that Im not sure what program you need for MAC ..but if you have a windows computer available to do that ..things are getting simple..just follow this video..
http://www.5min.com/Video/Windows-Movie-Maker---import-from-a-DV-tape-6876
So...if you have a movie maker in your Mac ..the procedure will be the same ,just playback in the camera ...be sure it is detected by the firewire cable...and record (import ) with the movie maker...
Please dont forget to rate if this helps...
May 09, 2010 | Canon Elura 90 Mini DV Digital Camcorder
I have a canon elura 60 and im trying to download my video to my computer so i can email it to someone. how do i do this?
you need a DV firewire cable and video capture software (there are several different program on the market)
Mar 31, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
Mar 30, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Panasonic NV-GS70 lost cd installer
Hi, I purchsed Panasonic NV GS-70 in 2004 and facing the same problem in transferring videos to computer. I tried for firewire cable option as well, but the camcorder does not have a firewire port.
Can anyone suggest what kind of firewire cable to be used for it.
Feb 11, 2008 | Panasonic NV-GS70 Mini DV Digital...
Can't download my video from my elura 40mc to new hp vista laptop
Go to canon's website navigate to its download page for camcorders, then plug in information about your operating system and download the new driver for Vista. Restart your computer, plug in cable and camcorder. Should work.
Additionally if you want clean up your registry, use free Eusing registry fixer to fix most problems. It is a stable product.
Jan 25, 2008 | Canon Elura 40MC Mini DV Digital Camcorder
Canon Elura 60 Mini DV Digital Camcorder Logo
128 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
