-   Recently the soap tablet container does not spring open during cycle. Catch seems OK and nothing blocking it from opening. Any suggestions or do I have to get the engineer as I do not know how to open the mechanism to check-   anden
this can either be the dispenser itself or the module which drives it. for a start, split the door and check continuity thro the dispensor coil. can also be caused by the plastic parts distorting. actuate manually and see if door flys open
on any cycle dishwasher drains, then fills but does not wash - is it the main motor or could it be...
(More)
on any cycle dishwasher drains, then fills but does not wash - is it the main motor or could it be the motor start cpacitor?
When I turn the d/washer on the main switch, The pump starts trying to pump and the first cycle...
(More)
When I turn the d/washer on the main switch, The pump starts trying to pump and the first cycle light starts to flash. That is as far as it will go through cleaning cycle! I've unplugged and tried to reset but always the same problem? Thanks
My dishwasher is approx 10 yrs old works fine but does not clean - the filters are cleaned out and i...
(More)
My dishwasher is approx 10 yrs old works fine but does not clean - the filters are cleaned out and i have put a dishwasher cleaner through it
The light that indicates the salt is always on, despite that i done it twice. Plus the dishes dont...
(More)
The light that indicates the salt is always on, despite that i done it twice. Plus the dishes dont come out clean and often covered in a white powdery substance. Any ideas. I havent use it much because of it. it is such a waste of money. Thank you
