Question about NorStar BCM-M7324 Corded Phone (nt8b42ac35)
Line 3 and 4 are not programmed
Just bought 2 more phones (m7324) for business and usually have 4 lines, but only line 1 and 2 are working on the new ones. how can I program line 3 and 4.
  • 31 Answers
You need to go into main programming of the system, and set the phone to access those lines. First ID the 2 new extensions. Do this by going to the phone, and pressing the Feature Key "Button with a little black globe", * and 0. then press the intercom button. This will show you the extension number. Press release "Red button with the phone and arrow downward". Then Press feature key "Button with the black Globe" "**266344" and again "**266344" go to terminals and sets. next to the buttons, you will see triangles , 3 for a while and 4 some times. The keys just next to them are your scrolling and enter keys. Scroll to "Terminals and Sets", press the enter button "Top right triangle" and enter in the extension and enter. then scroll to Line Access, enter, line Assignment. For each line, you have to change it to either Appear and ring, appr or unassigned. Set to appear and ring or appr. Do is for each extension to want to have acces to those lines.
Posted on May 23, 2007
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
Jan 18, 2016 | NorStar M7324 Telephone
Norstar M7324 not showing lines in use and unable to retrieve calls on hold
That might mean that the line(s) is(are) not programmed for that telephone. If you press feature * 0 then one of the line buttons, does it list as a line or blank?
Apr 22, 2014 | NorStar M7324 Telephone
Can I change the ring tone for just one of the lines on my nortel norstar phone m7324?
If your phone system has 6.1 software or up then yes,the tech or vendor can program it for you. If you know how to program look under Config/Lines for Ring Type.
Oct 17, 2012 | Nortel M7324 Refurbished Norstar System...
When I pick up my nortel norstar phone m7324 line 6 lights up can I change this to line 1?
In tech programming (Config) you need to got to the Line data and remove lines 2, 3, 4, 5 and 6 from the pool it is in, make it none.
Note if line 1 is in use then you cannot call out.
Note sure why you would want line 1 as your outbound, systems are to use the bottom lines out and work their way up and inbound starts at the top and works their way down.
If you dont know how to program or the password call your local vendor in for a 1 hour charge.
If there is some strange reason then state what the setup or issue is and we can see if there is a work around.
Nov 08, 2012 | Nortel Norstar M7324 Receptionist Phone,...
You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop. How though?
Changing programming on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) - display should read "lines"
4.- Press "SHOW" (top right arrow)- display should ask for a line number
5.- enter in the line number you wish to change the supervision on in a 3 digit format. ex. line 1 = 001
6.- press the show key (top right arrow)
7.- The display should say Trunk/line data
8.- Press "show"(top right arrow) - display should read "trunk type"
9.- Press the next key (bottom right arrow) 7 times"
10.- the display should say "trunk mode: unspr"
11.- Press softkey "CHANGE" to "super"
repeat steps 5 - 11 for the remainder of the lines Press the Rls key when finished
Nov 03, 2009 | NorStar M7324 Telephone
Norstar m7324 - forward to outside line
The solution for someone using the administrator phone (receptionist phone) is after discovering you have a fax call, depress the <link> button. Dial the fax number, wait for it to answer, then depress <link> again. This places call 1 with an outside number.
Apparently this is also available if you have a feature button by depressing <feature> <7> <1> instead of <link>. I haven't tried this so don't take my word for it.
This can also be used to forward a caller to an outside line, such as a cell phone. In the manufacturing business, our shop manager is never in the office. I may ask him if this is a viable solution.
Mar 23, 2009 | NorStar M7324 Telephone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Change name on a Nortel M7324
1. Press the Rls button then ** FEATURE 266344 (CONFIG)
2. Password is 23646 (ADMIN) The display reads Terminals & Sets
3. Press SHOW ans enter the Extension for which you want to enter a name.
4. Press SHOW, again
5. Press the NEXT key until the display reads NAMES at the top left corner.
6. The bottom right corner reads CHANGE, press the far right soft key.
7. To move from one letter to the next use the far right and far left soft keys or the # key.
8. When you are finished Press next.
9. Press the HEADING key to get back to TERMINALS & SETS and start again!
Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
Line 2 = BACK Last No. = NEXT
This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
Jan 28, 2009 | NorStar M7324 Telephone
Button Programming
It sounds like your service technician changed the Line Name to "dead" to let you & he know that line port was not working. Please check with your service company for further clarification.
Good Luck!
Dec 22, 2008 | NorStar M7324 Telephone
No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Oct 02, 2008 | NorStar Meridian M7310 Phone
NorStar BCM-M7324 Corded Phone (nt8b42ac35) Logo
112 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
