Question about Philips 24PT6341 24" TV
Problem with televisor phillips 27f8007583 chassis
I hava problems with televisor phillips. chassis 27f8007583, turn on alone and shows a white screen with numbers err 3 4 11 6 12,that may be the memory?thaks.
Philips 27f8007583 how to reset auto programming
Posted on Dec 18, 2010
I hava Holden commodore vz v6 having starting problems go to turn key on and sumtime it wont start take battery terminal of fiddle it around to get it going and sumtime it starts good..
Battery connections can be very deceptive and look good yet still not make good contact. Clean carefully and replace any ends of cables which show corrosion you cannot clean. Use some lube over the while connection once reattached (I like white lithium lube).
Feb 02, 2015 | Holden Cars & Trucks
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
My Phillips DVD player has a white screen. It will play the DVD but still show white screen.
The wire could be loose that connects the screen to the dvd player board, these are a common problem on alot of portable dvd players.
jon
Aug 10, 2009 | Philips PET702 Portable DVD Player
Really weird white/black screen
it may be a battery or an lcd problem. you may need to replace a part. pay this forum page a visit: http://modmymoto.com and see if someone can answer your question there.
Jan 26, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Mitsubishi wd52525 problems
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping.
go to www.tv-techs.com
Oct 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Phillips 42" flat screen ty
Well, I spent $20 on FixYa which did absolutely nothing and now and waiting for the Phillips to show up to take my TV to their shop (which alone will cost me $100 in itself) and wait for approximately 2 weeks to find out if the fix costs more than the TV is worth, in which case, I'll be out thousands of dollars, plus $20 to you, plus the Phillips charges AND whatever a replacement TV costs.
Did that answer your question?
May 19, 2008 | Philips Televison & Video
NG Pajero radio cassette wiring
the green/white wire is the earth - the earth to the chassis gave no resistance when tested with the multimeter to the car chassis. So it was a pretty good bet that the green/white wire was the earth as suspected. The radio cassette works a treat. Yipee!
Apr 18, 2008 | Car Audio & Video
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Philips 24PT6341 24" TV Logo
249 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
