Question about HP DeskJet F380 All-In-One Printer
Hp f380 all in one when scanning the image not clear its zooming
Hp f380 all in one when scanning (or) coping the image not clear its look zooming
    Genius:
  • 1,913 Answers
I think your resolution setings is changeing.
it is in software setings of resolution chagne t to 300*300 .
Posted on Dec 29, 2008
Hi. we have HP DESKJET F380 ALL IN ONE Printer-Scanner-Copier. but suddenly we cant refill the cartridge and we can't print any documents cause its always have error and we dont know what to do. also in...
I had this problem. My HP F380 also stopped accepting professionally filled cartridges too. The only solution was to start buying HP cartridges. Thankfully these are much cheaper on eBay than buying at the RRP in shops or elsewhere online.
Jan 19, 2011 | HP DeskJet F380 All-In-One Printer
Using my F380 all in one, how do I scan to my
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only.
To use the scan features, the HP All-in-One and computer must be connected and turned on.
The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To scan to a computer
1. Place your original print side down on the left front corner of the glass.
2. Press Scan.
A preview image of the scan appears on your computer, where you can edit it.
3. Make any edits to the preview image, and then click Accept when you are finished.
To stop scanning ➔ Press Cancel on the control panel.
If this doesn't work for some reason you should also be able to scan using windows camera and scanning wizard, the link will show you how if you have XP, just scroll down past the "how to print" section.
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
or this if you have Vista:
If you cannot find the scanner wizard it could be because your version of vista doesn't have it, I'm not 100% but I think it was only packaged with the business version of vista.
If this is the case then you can download a free program called IrfanView from there site: http://www.irfanview.com/
Click the Start icon. Click All Programs .
Click Windows Photo Gallery .
Click File and then click Import From Scanner or Camera .
Click Import .
Click Scan .
I hope that helps..
Regards
Mike
May 26, 2010 | HP DeskJet F380 All-In-One Printer
Printer hp deskjet f380
If you have Vista as your operating system, Windows Vista provides a basic set of scanning drivers, also referred to as Windows Image Acquisition (WIA) drivers, that you can use as an alternative to scan a document when you cannot scan using the HP drivers.You can still scan with one of the following methods:
(Click here) workaround
Feb 10, 2010 | HP DeskJet F380 All-In-One InkJet Printer
How do i scan using a HP desktop F380
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    Want to scan pictures
    install the complete software of ur device and then you will be able to scan images through software. you can download the software from www.hp.com also.
    dont forget to vote...
    Sep 13, 2009 | HP DeskJet F380 All-In-One Printer
    Scanning a photo
    Make sure you have the HP imaging software installed and running first if you dont you can download the Vista version HERE that should do it
    Jun 30, 2008 | HP DeskJet F380 All-In-One Printer
    Hp software for f380
    The drivers and scan software can be downloaded from here or there are also links to order the CD from HP.
    The full download is about 163Mb, if you have a slow connection you may want to order the CD. Typically the CD is free but there is a shipping charge of ~$10.
    Regards,
    Bob Headrick, MS MVP Printing/Imaging
    Jun 22, 2008 | HP DeskJet F380 All-In-One Printer
    HP DeskJet F380 won't copy
    If you can't get it to scan an image then you might have to have it brought to a repair center. How often do you use the copy function? Scanning function?
    Mar 27, 2008 | HP DeskJet F380 All-In-One Printer
    HP DeskJet F380 All-In-One Printer Logo
    63 people viewed this question
    Ben Johnson
