Sony VAIO VGC-RB40 PC Desktop Logo
Posted on Dec 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I copy system32\config from VAIO Recovery Disk
I have the original restore CD's but when I install 1/2 disk it seems the only option is a full restore wiping out drive info, is that the case or is there a repair option?
Anonymous
Level 3:
Genius:
  • Master 1,913 Answers
  • Posted on Dec 29, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1913
Questions
5
Helped
687842
Points
5322
First go to command prompt with recovery console.
then type chkdsk /r
tehn press y
then restrt the copmuter then it fix the harddisk error.then it will be fine.
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
tip
How to do System Restore when the computer doesn't even boot to Safe Mode in...
System Restore is assumed to be the best method to recover the system from Registry or System file errors. Its easy to perform and is effective, no doubt. But what happens when the system doesn't even boot to the desktop, neither in Normal mode, nor in Safe Mode. How do you do a System Restore then. For Vista and Win 7 users, its a piece of cake, since the WinRE provides them the direct option to System Restore from the installation/repair CD. But what for the XP users?
The following method is very useful and serves as a bliss for Windows XP users to recover their system from crashes due to Registry or System file failures. All you need for the method is a Windows XP installation CD. (This is not a re-installation process. All data and settings are intact after the operation.)
Step 1: Boot to the Recovery Console
  • Insert the Windows XP CD into the computer.
  • Turn the computer off.
  • Setup the computer to boot from cd: either by pressing F2, F9 or Delete to go in BIOS and changing the boot sequence or by pressing F12 on Dell computers to launch the Boot Device Menu.
  • As soon as you get the message 'Press any key to boot from the cd', hit enter.
  • Wait for the Windows Setup to initialize
  • At the Welcome to Setup screen press R to repair windows using recovery console.
  • You will be prompted to choose a Windows installation. Press 1 on the top of the keyboard and then press Enter.
  • You will be prompted to enter the Administrator password. Press Enter if no password was set.
Step 2: Accessing the Restore points.
Type the following commands in the Recovery Console.
cd system~1
If you get an Access Denied error:
  • Type the following commands to change the directory to c:windowssystem32config:
    cd windows
    cd system32
    cd config
  • Rename the system branch of the registry. That will allow us to access the system restore folder from inside the Recovery Console. In case the process fails and you want to perform a Windows Repair you will need to rename system.bak to system again.
    ren system system.bak
  • Type exit to leave the recovery console and to restart the computer.
  • Go back into the Recovery Console and repeat Step 2.
cd _resto~1
If the _resto~1 folder exists, inside it there are several folders named RP1, RP2. These are restore points. RP1 is the oldest restore point. You can use dir to view what RP folders are available. If there is no _resto~1 folder or if there are no restore points inside it:
  • Type the following commands:
    cd
    cd windows
    cd system32
    cd config
    copy c:\windows\repair\system system
  • If you are getting a file not found error try:
    copy c:\windows\repair\system.bak system
  • Then type the following :
  • copy c:\windows\repair\security security
  • copy c:\windows\repair\software software
  • copy c:\windows\repair\sam sam
  • copy c:\windows\repair\default default
  • exit
  • You will be able to boot into a altered version of the operating system. Backup your files from the c:Documents and Settings folder and then reinstall the operating system.
Step 3: Choose the most convenient RP folder.
Supposing we have RP3 available let's type in:
cd rp3
Change the directory to snapshot:
cd snapshot
Step 4: Restore the main registry branches.
If you are being asked if you want to overwrite type in y to agree.
copy _registry_machine_system c:\windows\system32\config\system
copy _registry_machine_software c:\windows\system32\config\software
The following commands are most of the time optional however the process might not work if they are not executed
copy _registry_machine_security c:\windows\system32\config\security
copy _registry_machine_sam c:\windows\system32\config\sam
copy _registry_user_.default c:\windows\system32\config\default
Type exit to reboot the system. Start the computer normally.
Thanks,
Abhishek
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
1helpful
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
4answers
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
2helpful
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
2answers
Hp paviliondv2050us wont start
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
2answers
Windows XP Missing configuration?
Sounds like you may have bad RAM. Try removing all of the RAM modules on your motherboard and put only one in the first slot. Start the computer and see if it works.
3helpful
4answers
I have deleted svchost.exe from windows xp
WINNR\SYSTEM32\CONFIG\SYSTEM error
do it
1.
Use the Windows 2000 CD-ROM or the Windows 2000 Startup disk to start the computer. 2. When you see the "Welcome to Setup" message, press R for "repair." 3. Press C to run the Recovery Console tool. 4. Select the installation that you want to repair. 5. Type the administrator password.
If the computer is a domain controller, type the password for Directory Services Restore Mode when you are prompted to do so.For additional information about the Recovery Console tool, click the article numbers below to view the articles in the Microsoft Knowledge Base: 239803 (http://support.microsoft.com/kb/239803/EN-US/) How to Change the Recovery Console Administrator Password on a Domain Controller 223301 (http://support.microsoft.com/kb/223301/EN-US/) Protection of the Administrator Account in the Offline SAM 6. At the Recovery Console command prompt, type the following commands, pressing ENTER after you type each command: cd system32\config
ren system system.old
ren system.alt systemalt.old
7. If you have run the Emergency Repair Disk Wizard from Windows Backup and Recovery tools, copy the backup of the System hive from the %SystemRoot%\Repair\Regback folder.
If you have not run the Emergency Repair Disk Wizard, copy the default System hive from the %SystemRoot%\Repair folder.
IMPORTANT: You need to restore the most recent copy of the System hive. You also need to reinstall any hardware device drivers or programs that run as services that you installed since the last time that you updated your Emergency Repair Disk.
To copy the default System hive, type the following command, and then press ENTER: copy c:\winnt\repair\system c:\winnt\system32\config To copy the System hive that was backed up the last time that you ran the Emergency Repair Disk Wizard, type the following command, and then press ENTER: copy c:\winnt\repair\regback\system c:\winnt\system32\config 8. At the command prompt, type exit, and then press ENTER to restart your computer.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
