Question about SATO CL 408 Thermal Label Printer
Will not print white on black
My SATO will print everything fine except white fonts over a black background. I've tried inverse cell on Excel, and I've tried to use a white font over a black fill-and yet the sato always prints a solid black box. Help!
  • 43 Answers
Hi you need to change the font colour of your priter == for this you can go to the properties of the printer and change the colour = this may help you = Good Luck
Posted on Apr 27, 2007
Wont print in full black, does print in grey or any other colour.
Assuming you are using MS Excel, try going into page setup, sheet, and check the setting for 'print black & white'. If it is checked, then try unchecking it.
Apr 18, 2016 | Office Equipment & Supplies
Tip
TOSHIBA DVD REGION FREE HACK METHOD.
1. Power on.
2. Open tray.
3. Push the info on remote once (with supplied remote). You will see numbers.
4. Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
5. Power off.
Power on.
on May 21, 2012 | Toshiba Televison & Video
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Aficio SP C411DN does not print cyan
Well, since you've tried everything, my recommendation is to try to clean the contacts with dry cloth in the left or right side inside the printer where the cartridges place in. see the result
Feb 01, 2014 | Ricoh Aficio SP C411DN Laser Printer
White lines in my printing and sometimes smudges of black ink
Hi
First before you buy a new cartridge,try doing a 'printhead' cleaning on your machine.Sometimes the printheads need cleaning clogginl.
Mar 03, 2012 | Office Equipment & Supplies
Bar code printed on sato m5900 Rve printer will not scan. Same bar code printed on HP laser WILL scan. Font used is ID Automation 39 - prints at 6 pitch
Are you printing in thermal transfer mode or on thermal direct stock? Sounds like your image is not black enough for your scanner. Things to check: adjust printhead temperature, change ribbon stock, change thermal-direct stock, adjust scanner's sensitivity.
Jul 18, 2011 | SATO M5900RVE Printer
I have a new laptop and now everything is printing with a black background and white print. How can I change the settings to stop this?
Under control panel - Printers
Right click on printer icon and select Printing preferences
Check under settings if Inverse printing is enabled, if so disable it.
Or the best you can do is to uninstall and reinstall the printer drivers.
Oct 12, 2010 | HP Compaq 515 (FM947UT) PC Notebook
Excel 2003 cell is highlighted, font color is selected, but the color on the screen remains black. When printing the color prints out correctly while showing black on the screen
to remove all formats....
i.e.
open another workbook....
copy all data from the present sheet to the new work book....
present workbook
select data/edit/copy
new work book
select cell edit/paste special/values
now do the formating/color/font/size etc in the new workbook and check if they work here
Dec 14, 2009 | Microsoft Office Excel 2003 for PC
Pages are printing out with solid black background w/white font
On many machines there is a "positive/negative" setting that can be set that would produce this output...check your settings.
Apr 18, 2009 | Office Equipment & Supplies
SATO CL 408 Thermal Label Printer Logo
123 people viewed this question
Top SATO Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
M_Butkus
 steve
steve
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
