Question about Apple iMac G5 Desktop
Picture distortion on desktop monitor
On my monitor close to the top of the screen the picture does not quite meet up, i.e. a split image as if an imaginary horizontal line is running through the screen. This means that if there is a game icon on the top right hand of the screen for example the actual top half of its name is cut off. Bit hard to describe but hopefully someone will understand what I mean and offer some solution. Have tried restarting, changing the background and resetting the PRAM.
    Novelist:
    Champion:
  • 233 Answers
Most monitors have a MENU button. Get into that and you can adjust screen positions, etc.
Posted on Dec 30, 2008
    Genius:
  • 1,913 Answers
Ok when upower up the computer pres F8 key thwn go to enable vga mode.then set resulution settings to 1024*768.
Posted on Dec 29, 2008
Unlock screen
try a force quit of iphoto
Apple menu -->
Force quit
Dec 30, 2013 | Apple 24" iMac Desktop
Grey side bar on desk top screen
The picture or image you have chosen does not fit the screen. Go to your system preferences, Desktop &Screen Saver, click on the desktop tab and change the image to "fit the screen" or a variety of other options.
Nov 09, 2013 | Apple Computers & Internet
Screen ghosting
That is a shop job, checkout main board systems
Mar 04, 2013 | Apple iMac 24" Desktop
Circle icon won't shut down apps on mac
We really need a little more info to answer this correctly. Which Circle Icon are you clicking to "shut down apps"?
In OSX, there are three circles or dots at the top-left of every active window. These are, starting at the left, Red: Close this window, Yellow: Hide this window, and Green: Maximize/Restore this window. Note that none of these Close or Quit the Application, only that particular window or instance of that app.
To actually Quit a particular application or program, you can use the keyboard command: Command-Q, or you can click the application menu and select Quit.
Feb 15, 2013 | Apple iMac G5 Desktop
Split screen left side magnified right side regular how to quit?
Which version of OSX are you running?
Check in System Preferences under the Apple menu, then click on Accessibility and un-check the Zoom feature.
Also check Displays in System Preferences as well.
Oct 17, 2012 | Apple iMac Desktop
I turn on my imac and it makes the boot sound but the screen doesnt turn on what should i do?
Attach an external monitor to the port on the rear of the iMac (requires a mini-VGA to VGA adapter). If the external monitor shows image, then you have a bad inverter or LCD panel, or a disconnected display cable. If the external monitor shows no image, then it is something else, and whatever it is will probably require a logic board replacement, which is not cost-effective in a machine this old (unless you have an unusual source of used parts).
Oct 25, 2010 | Apple iMac G4 Desktop
Computer sounds like it is starting up but screen is black - is it possible that the monitor has gone bad? Or does that suggest something worse?
It is quite possible that your monitor has gone bad with age or impact. Fastest test is to hook up a separate display using the auxiliary monitor port -- if you get an image on that monitor but not on your main monitor, and the rest of the computer operates properly, your LCD panel or inverter has gone bad.
Either is a relatively simple fix for a certified technician. The inverter MSRPs for $60-80 but can be found for as little as $16 used. The LCD panel MSRPs for $250-300, but can be had for as little as $80 used. Prices quoted are for the 17" version iMac.
Jun 04, 2010 | Apple iMac G4 Desktop
I hooked a different monitor to my HP computer and the icons and pictures on the monitor look **** comic drawings insted of sharp pictures like the old monitor. How do I fix this?
go to display properties and adjust your screen resolution: right click on the desktop then select properties (xp) or personalize (vista/7). then, in xp, go to the settings tab. in vista/7, click on display settings.
Dec 25, 2009 | Computers & Internet
I have a 15" ELO lcd monitor picture is dim ? but when it sits for a minute and reboot it the picture gets brighter but a lot of red then picture goes very dim i am able to see menu so brightness is 100%...
Make sure that there is no devices that has magnetic properties that might cause this, such as speakers, cellphones/telephones, microwave oven, refrigerator, etc. These kind of devices/machines can degrade the quality of the LCD monitor. If no devices are close enough to the monitor for interference, then you should try to check the data cable from your monitor to your system. The data cable (usually with a blue connector on both ends) should be properly connected at the back of your computer and your monitor. It has screws at the side of the connector to fasten it. Also check the power cable, connect it to another outlet. If it still persist, the LCD screen itself could already been damage. You should replace it, or if it's under warranty, call the manufacturer.
Dec 01, 2009 | Computers & Internet
Apple iMac G5 Desktop Logo
525 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
